Question about Intel (P42000400512SK478) Pentium 4, 2 GHz Processor
Processor over heating
in my system all the fans are stopped after few mins when i boot up. i changed the motherboard and put a new one.again same problem. then i changed the smps,hard disk , ram,cpu fan, cabinet. then also same problem. then i removed the processor and power on.. now its works. so i changed the processor which was working perfectly in another system. then again i power on.. same problem again. then i removed the new processor and put into its orginal machine.. now both the system's fans stops after few mins. what will be the problem? there is no restriction for the fan in the bios.
please do reply.
Suresh
[email protected]
Posted by sureshsv2k on
  • yutt Dec 16, 2007
    i have PIII when i boot my pc they have an error message.. the message is searching for floppy disk so i try to disable my floppy disk in cmos set up then same problem again when i boot my pc.. so whats the problem.. thanks \god"
Anonymous
    Problem Solver:
  • 42 Answers
Yutt...
try to change the boot priority in the bios,set the hard disks as the 1st priority.if this will not help...clear your cmos by finding the pin in your motherboard to clear the previous setup and power on again...or check your floopy disk if its connected properly or set your bios at default...
Posted on Feb 01, 2008
Anonymous
  • 3 Answers
Well, Problem could be complex if your not that knowledgeable in CPU are, the best thing for you to do is buy new CPU complete set or if there is a warranty contact the company where you bought your computer. They might have more way of helping you in this type of situation. If you have broken the seal the warranty will not be valid anymore. If your CPU is 3yrs old from the day you used it then you might encounter lots of problem because of either flactuation of electricity or probably somesort of low quality product which have a short life span. this day most of computer and other new tech gadget are usually problematic due to using nano chips. and low quality product. HOPE THIS HELP YOU.
Posted on Dec 18, 2007
Anonymous
  • 63 Answers
This is normal behavior. Fans normally only run when they are needed, and your computer has multiple temperature sensors that direct this behavior (they are primarily located on the CPU, which could explain why the fans all worked when you took the CPU out). You should only be concerned about the fans stopping if your computer is, indeed, overheating.
Posted on Nov 19, 2007
Can't get my system to boot up
The power mapping grid on the motherboard may be defective
Sep 15, 2012 | ASUS P8Z77 WS Z77 LGA 1155 ATX Intel...
AMD Athlon 64 X2 Cooling System Failure: My computer suddenly turned OFF as if it was unplugged. i opened the cpu casing and cleaned the inside hoping it will solve the problem, but when i plugged the...
Hello
Sounds like you need a new cooling fan.You may be able to save yours with some electrical contact cleaner spray.
Remove fan and spray.
The cpu will heat up quick and shut down everything to protect itself.Im sure once you get a new fan you will be up and running again.
You may consider reapplying new conductive paste to the processor while you have the case open.
Aug 09, 2011 | AMD Athlon 64 X2, 2 GHz 4600+...
I run the computer for about 30 min. sudenly it will stop showing anything in the monitor i try it to open but there is no boot and no picture , and i check even the processor heat sink is not produce heat
hmm!! there is problem with your processor's heat sink only!!! your system is getting over heated so it shut downs automatically to prevent damage!! i have also gone through this problem!!! try changing the processor's fan!!
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
POWER LED ON BOARD SHOWS THAT IT IS ON BUT SYSTEM DOES NOT BOOTS
Hi...
If that problem is happen check the monitor cable if it is correctly plug to the motherboard, if your motherboard have video card attach try to remove the video card, if the same things happen thee problem is the processor, you need to check the processor, remove it and clean then put a thermal paste so that the heat from processor will absorb by the heatsink, and be sure that the heatsink fan it working to prevent the heat.
Good luck !!!
Regards
PCmania
Jul 10, 2009 | Intel Desktop Board D815EEA2 Universal...
Algerian-47
you could try removing power lead then remove battery from m/b for 5 mins this will reset bios back to maufacturers settings then replace battery and power then try boot up if no luck then change motherboard
Jul 01, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
My emachine shuts itself off, fan working ok, help help
Hi there. When you turn on your system, enter the BIOS setup screen. Depending on your BIOS, you may have a section that tells you the PC Health Status. If you do, you can check what temp your processor is, and it may even let you adjust the warning temp, (it may be set too low). Some BIOS's will shut down a machine automatically if this temp is reached, to save the integrity of the system.
Yes, you may have a faulty power supply. Try testing it with another and see if the same thing happens. Also, make sure that your power supply is connected to your motherboard properly. Easiest way is to just disconnect it from the motherboard, check for any bent/broken pins, then just click it firmly back into place.
If you need me to clarify anything, just post a comment.
Tim
Apr 20, 2009 | Computers & Internet
Processor Overheating
It is important to use good quality thermal paste like Arctic Silver. You only need a very small amount on the heat sink. Too much is as bad as none at all. You care just trying to create a thin layer of thermal paste to fill in the tiny gaps between the processor and the heat sink. If this does not help an aftermarket heat sink with more fins and a better fan might be needed.
Mar 18, 2009 | Intel D865GVHZ Motherboard
Regarding Intel DG33FB Motherboard
Try replacing with a known good power supply and try it from there. Could be power supply problem
Sep 23, 2008 | Intel D865GBF Motherboard
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
Cpu fan stopps
try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Nov 14, 2007 | Computers & Internet
Intel (P42000400512SK478) Pentium 4, 2 GHz Processor Logo
54 people viewed this question
Top Intel Computers & Internet Experts
Ekse
Lee Hodgson
Lee Hodgson
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
