Net problem. when i open any folder in network then some error showe .error is handle is in velide.i am using os is windows xp.
Posted by jeenu on
Anonymous
    Novelist:
  • 85 Answers
This is likely a communication error with the drive or network resource you are trying to contact. If it is on a network, you have either lost the connection to it, or it is having protocol problems when trying to access files. If it is a USB device, it is likely getting USB conflicts from another device that is buggy (often an MP3 player or hub, I've noticed).
Hope this helps...
Posted on Nov 16, 2007
I have the scanner set up and able to scan, however I need the scanned documents to be transmitted into a network folder. This is not happening and so the scanned documents are going god only knows where....
Some scanners have a hard time when configured to save to a network folder using a UNC [Uniform Naming Convention] path.
Sometimes you can bypass some of these issues by mapping the network folder to a local drive letter then making that drive the save location for scanned files.
Are you at liberty to share what Make/Model scanner is in use?
How to disconnect and disconnect a network drive:
Windows XP
  • To map a network drive:
    1. Click Start, and then click Run.
    2. In the Open box, type cmd.
    3. Type net use x: \\computer name\share name, where x: is the drive letter you want to assign to the shared resource.
  • To disconnect a mapped drive:
    3. Type net use x: /delete, where x: is the drive letter of the shared resource.
May 05, 2011 | Computers & Internet
Tip
How to fix a error 48 with itunes
The message does not indicate that there is an issue with the iPod but that that iTunes was unable to read the iPod software update it uses to restore or update your iPod. You can delete the folder containing the iPod software update files so iTunes can download a new copy of the iPod software update.
Here are the steps to take if you get this message:
Eject iPod and quit iTunes.
Use Disk Utility in Mac OS X or run chkdsk in Windows to verify there are no other issues on your hard drive.
Locate the iPod Software Updates folder:
In Mac OS X, the folder is
/Users/username/Library/iTunes/iPod Software Updates
In Windows Vista, the folder is
C:\Users\username\AppData\Roaming\Apple Computer\iTunes\iPod Software Updates
In Windows XP and Windows 2000, the folder is
C:\Documents and Settings\yourusername\Application Data\Apple Computer\iTunes\iPod Software Updates
Note: If you don't see the files in Windows, turn on the Show hidden files option.
Windows Vista: Open Computer and choose Folder and Search Options from the Organize menu.
Windows XP and 2000: Open My Computer and click Folder Options from the Tools menu.
Click the View tab.
In the Advanced Settings pane, select the "Show hidden files and folders" button.
Click OK.
Drag the iPod Software Updates folder to the Trash or Recycle Bin.
Connect iPod and open iTunes. You will need to be connected to the Internet to download the files.
Then restore
on Apr 25, 2010 | Computers & Internet
Tip
How to fix error 48 in itunes
Click the View tab.
Click OK.
Then restore the ipod agin -
The folders for the iomega storage drive no longer are displayed on my computer, and when opening up my network it shows the folders listed there but gives the error, "\\Network storage\public is not...
Make sure you are logged in as the Administrator of your computer. Power cycle (turn it off and back on) the device. If that doesn't fix the problem. Try factory resetting the unit (depress the reset button on the back of the unit for 4-5 seconds).
Dec 14, 2010 | Iomega 1TB Home Media Network Hard Drive...
Network issue
Hello
This is an unusual error. Error Code 1236 - The network connection was aborted by the local system.
There is no single issue that causes this error code, so we need to verify all of the networking basics are covered and working.
1. Verify the IP address, Subnet Mask and Default Gateway are fully entered and / or populated by the DHCP server. Click START, then RUN, type in CMD then click the OK button. Type IPCONFIG /ALL - verify the three fields all have valid info for your network.
2. Verify you can see the local network - including other computers and network devices. This will rule out the possibliity that this computer cannot see any network devices and not just the shared folders
3. Log the user out and have another user that can access the shared folders log into this comptuer and try to access the shares. The user profile could be corrupted and preventing the user from accessing the shared folders. IF the new user cannot access the shared folders, then it is the PC / OS causing the issue. IF they can access the shared folders, backup the original user's data, delete their profile and have them log in again to create a new profile.
It is always recommended to upgrade Windows XP to Service Pack 3 - unless you have a very specific program that will not run on SP3.
May 04, 2010 | Microsoft Windows XP Professional SP2
BSNL net connects but after some time svchost.exe error occurs
The problem is with the Windows operating system. Either the OS is infected by a virus or it is corrupt.
The best and effective thing I can suggest you is to reinstall the Operating system on the computer. Please scan your computer once you have reinstalled the OS using a good antivirus.
Hope this helps.
Jan 12, 2010 | Microsoft Windows XP Professional
While installing xp showing error
Hi Friend
Try this may help you in creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. (You don't need to change the BIOS if you have an ATA or IDE hard drive.)
Next, insert your Windows XPmag-glass_10x10.gif CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. (To do this, right click the Computer icon in start, and select manage. Then select Disk Management, and you can do whatever you want with your partition.)
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating systemmag-glass_10x10.gif files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
I hope this will help you out. Please vote for me.
Oct 06, 2009 | Compaq Presario Notebook
Hi, I ma trying to connect my gestetner DSM415f to my home network. I have the wim open and hve pinged to be sure that it os being picked up. I am trying to set the machine up to scan. I am operating...
Folder must be fully shared, (full control for everyone.) create a user name and password that has admin priviledges. Enter this info in Config>File transfer>SMB.
Enter the path to the folder in the address book, in this manner> \\name of computer folder is on\name of directory\name of folder.
Sep 07, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How can i view my hidden files ?
Show hidden files
Follow these steps to display hidden files and folders.
  1. Click to open Folder Options.
  2. Click the View tab.
  3. Under Advanced settings, click Show hidden files and folders, and then click OK.
Aug 23, 2009 | Microsoft Windows XP Professional With...
Crashing during Windows Setup
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works. or remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one cheers!
Sep 17, 2006 | Microsoft Windows XP Professional for PC
Computers & Internet Logo
Ekse
Marvin
Marvin
