Your turntable belt is off. Remove the c-clip holding the platter to the center spindle. Remove the platter and turn it bottom side up, place the rubber belt around the platter and fix it to the little post sticking up on the outer-edge surface. The little post holds the belt to the platter while you turn the platter over and put it on so that the post points right over the motor pulley. Turn the platter by hand either clockwise or counter-CW and the belt will pop off of the post and land on the motor pulley. One drop of oil on the center spindle for lube and fasten the e-clip back on. Of
course, the tone arm might not be actuating the power switch, you can address that with the platter off as well. Good Luck.
Can you clarify? Is the sound you hear audible through the air or only through the cartridge to the electronics? If the former, can you get it to happen while just manually rotating the platter? Investigate for foregn matter inside the unit. If it's only through the cartridge you might have a serious problem with the stylus or tracking force.
