The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Your DS is either fully charged or the battery got damaged/wet. When you play the DS, is the light red or flash red? If it does, then the problem is with your battery. http://www.nintendo.com/consumer/repair/dslite_repair_home.jsp
Click on your country, then "System and Game Problems," then "Power and Battery Charging Problems."
Hope this helped.
First of all, your DS Lite is charging both ways.....with power on and without power on. You have for almost 99% sure a blown fuse F2 on the systemboard. If you can solder you can try to replace it with a new one but be adviced, it is tricky if you don't have the skills with soldering SMD components and it can send your DS lite to the trash. So my advice is find someone that repair DS Lites or order a fuse on eBay and try it yourself.
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
I know that this is probably not the answer you guys want to hear about this issue...
You're going to have to contact Nintendo and make good on your warranty on this one. Just tell them that the unit is no longer charging and that you 'don't know why'. They should have no real problem replacing it for you.
This is most likely an internal electronics issue that no expert here is going to be able to advise on.
Unfortunately the internet still isn't good enough that we can do solder jobs over our internet connections. :P
=THIS IS NOT A PROPOSED FIX. DO NOT RATE ME FOR IT= Otherwise, if you wish to persist in trying to fix your problem, the only thing that I can tell you is to either try using someone else's charger adapter, buy a new adapter OR use an adapter that works and hold it at different positions in the DS Lite to see if any position will charge it. If you are succesful at charging it in this manner then the port you plug the charger into may be loosened.
===DO NOT RATE ME FOR THIS POST. IF YOU GIVE ME A POOR RATING FOR THIS
POST I WILL DISPUTE IT WITH THE FIXYA STAFF AND ASK THAT IT BE
REMOVED. I AM NOT ATTEMPTING TO SOLVE YOUR PROBLEM BUT AM GIVING YOU
ADVICE ON WHAT YOUR BEST BET IS. I WILL however accept a GOOD rating if it is given - naturally. LOL===
