SOURCE: How do I replace Serpentine belt on 92 gmc Sanoma.
should just have to turn the tensioner and pull belt off alternator pulley, release tensioner ,remove belt. install new belt, apply tension to tensioner and put belt back on alt. pulley.will require 1/2 in ratchet or serp. belt tool.
SOURCE: front bumper removal
all you have to do is unbolt it. if the nuts won't budge spray them with wd40 and wait over night for that product to loosen up the rust.
SOURCE: What do I have to do to remove the front bumper on
first remove plastic around and under bumper then acess bomper bolts from under truck make sure any lights are disconeccted before dropping bumper
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_00678fd4800d19c5
SOURCE: Removing brake calipers to replace pads.
Try this Video, I think they got the model right.
Just skip ahead to the disassembly procedure.
http://video.google.com/videoplay?docid=-4304104627961736795&ei=5-2VS7uxKYGhlAfvhcWcAw&q=brake+repair&hl=en&client=firefox-a
SOURCE: 1994 Sonoma: 1994 GMC Sanoma with 4.3 fuel injection. Idle spee...
that is un adjustable you would have to change the idle postion sensor
