Question about HP DeskJet 940c InkJet Printer
Red light flashing above ink symbol but plenty of ink
  • 43 Answers
Hello! the ink indicator is showing because the catrigde sensors could be coated by some dirt or ink . try cleaning the catridges slot with soft material .then put it on
Posted on Jul 10, 2009
Posted on Aug 11, 2009
How can I rectify canon mp210 printer ink absorber full
Are you using fine ink cartridges? Is your printer still working normally besides the flashing lights?
Aug 12, 2014 | Canon PIXMA MP210 Photo All-In-One Printer
R200 both red lights flashing
if both red lights are flashing alternately your printer has been locked this is due to full waste ink pads. you need to have them replaced either at your local service centre or do it yourself then you need a scss reset utility to reset your printer you can get a free one of these on the net
If your lights are flashing continuously look to see if you have any outstanding documents in your print queue and delete them
Mar 30, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Red light flashing, And little cartridge symbol on printer screen,
hi i,m iskandar how cant solve the trouble for flashing led resume hp deskjet f2180 thanks
i wait yor reply solution
regrads
ISKANDAR
[email protected]
Jan 23, 2009 | HP Deskjet F2180 All-In-One InkJet Printer
Ink issue
Normally if it's an ink cartridge problem, you will see there is a small cartridge symbol being shown in the right hand side window. If there isn't a cartidge symbol then it doesn't need a new cartridge. Normally when the red light flashes, it means there is some other problem such as paper jam or no paper! To change the cartridge, open the top of the printer, you'll see the cartridges on the right hand side, they should hopefully just pop out when you pull them GENTLY. To insert a new cartidge, follow the pictures shown and make sure you hear a 'click'.
I am not a techie at all so I hope this helps
Oct 06, 2008 | HP Photosmart 7850 InkJet Printer
Stopped printing
The printer will stop with an audible "clunk", and the symptoms above if the used toner container is full.
Sep 06, 2008 | Samsung CLP 300 Laser Printer
HP 932 RED LIGHT STAYS ON
The light you describe is the ink light.
When that light is blinking, try this.
Turn on the printer. Open the front cover and look at the carrier for the ink cartridges. There is a white arrow right above the latch for the color cartridge.
Once the carrier stops moving, the white arrow should be pointing to a symbol which represents the problem (the reason the light is blinking.) Examples are low ink black, low ink color, sick black ( replace ) , sick color ( replace ).
IF you have just replaced your black cartridge, you might need to replace your color cartridge too.
This printer will not work without both ink cartridges installed and full.
You cant print with a full black and an empty color cartridge unfortunately, even if you only want to print black.
Hope this helps!
Aug 27, 2008 | HP DeskJet 932c InkJet Printer
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
HP DeskJet 940c InkJet Printer Logo
1,486 people viewed this question
Ekse
Thomas F. Schneider
