There should be a latch to prevent opening the sliding door opening when the fuel cap door is open. It could be malfunctioning.
There is a cable from a push knob behind the fuel cap door which goes to a latch below the sliding door approx 15 cm's or so from the front side of the door opening.
I would check that the push knob or latch is not stuck in the open position allowing the sliding door to open when the fuel cap door is open. Try to push/pull the knob inside the fuel cap door and make sure it goes in / out freely, if this knob is stuck you could try a squirt of WD-40 (or similar) and see if you can gently grasp it with a pair of pliers and get it to slide in/out freely. Do this while the sliding door is closed.
If this doesn't fix the issue, remove a rear interior panel from the sliding door, you should see the cable, check that it is intact and adjusted correctly.
Trust this helps, regards Alan
Yes, close the door.
SOURCE: 2005 Toyota Sienna XLE - Automatic sliding door not closing.
This may or may not work depending on exactly what is wrong with the door, I cant tell what is wrong without looking at it directly however:
You can try starting with all doors closed and unlocked, keys in hand disconnecting the battery and letting the vehicle sit for 2 min or so, then reconnect the battery. Put the key into the ignition and turn it to the on position but do not start the van. Next press the button to disable the power sliding door for the drivers side, then manually open the door fully, wait 5 seconds, then close it manually fully. Press button the button again to re-enable the power sliding door, then try to use it with the automatic feature either by pulling the handle or using your remote, this may or may not work depending on if the door has somehow become de-initialized (it should work now) however if something is broken inside the door closing mechanism or door closed/open sensors, the door will continue to malfunction.
SOURCE: 2006 toyota sienna xle awd passenger sliding door
do u ty trunnig off the child lock? it maybe a saftey ?
