1994 Toyota Camry Logo
Dave McNeil Posted on Apr 10, 2015
How do i access the license plate light bulbs
John DoUhaveaneedtoknow
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 10, 2015
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
3210
Points
15
Access behind the bumper the wires lead you right to the light socket. The problem is theses bulb sockets corrode. Replacement sockets have to be purchased and wired in. They can cost $6.99 all the way to $39.99. I purchase two for under $20 at a local auto store. I used a soldering iron and heat shrink tubing with a heat gun to repair mine - they already outlasted the original sockets lifetime. They do sell some kits that pierce the wire avoiding soldering and heat shrink tubing BUT if you live anywhere up North where it snows or down South near the salt air from the beach - the wires will corrode where pierced. My truck just turned 15 years old this year. Springfield, MA
License plates bulb replacement
The license plate lamps are designed to illuminate the plate and registration tags on your vehicle and make it easily visible to law enforcement. In many states, a burnt out license plate bulb can get you a ticket.
Step 1: Locate the license plate light. The license plate light is located right above the plate.
Step 2: Determine which bulb has failed. Park your vehicle and set the emergency brake. Turn the ignition to the Accessory position and turn on the driving lights. Walk around the vehicle to determine which license plate bulb has failed.
Step 3: Remove the license plate light cover. Remove the license plate light cover retaining screws using a screwdriver.
  • Note: You may need to use a small screwdriver to pry the cover off.
Step 4: Remove the bulb. Remove the bulb from its retainer.
Part 2 of 2: Install the bulb Materials Needed
  • Protective gloves
  • Replacement license plate light bulb
  • Safety glasses
  • Screwdriver
Step 1: Install the new bulb. Install the new bulb in its retainer and ensure it is in place.
  • Tip: Refer to your car's user manual to determine the correct type of light bulb to get for your specific vehicle.
Step 2: Complete the installation. Put back the license plate light cover and hold it in place.
Install the license plate light cover retaining screws and tighten them using a screwdriver.
Step 3: Check the lights. Turn on your car to check if your license plate lights are fully functional.
Plate light does not work, but lights are good and sockets seem good
check bulb the number plate light runs on the same circuit as the side lights so if they are working its got to be a bad earth on the plate light
1helpful
2answers
Tail lights work but why don't license plate lights?
The license plate lights have their own separate bulbs. If you are able to replace the bulbs, that may solve your problem. If not, you may have a loose or rusted connection to the plate bulbs only. If you are able to gain access, you may want to check the condition of the harness that supplies the power to the license plate portion. Good luck and have a great day.
1helpful
How do I get to the license plate bulb for a 2004 nissan sentra
There are 2 bulbs above the license plate, each under a plastic cover. The covers are held in with 2 screws each. Just unscrew and remove the plastic covers and you should be able to access the bulbs.
2helpful
HOW TO CHANGE LICENSE PLATE LIGHTS ON 2004 PRIUS
Here is an article on switching over to the LED bulbs, but it shows you what must be done to access the lic plate bulbs as well.
2helpful
Need to replace bulbs that lights license plate. License plate and light is part of trunk
raise trunk lid look on the inside behind your license plate light there should be access to the bulb there. You will see the wires going in to the bulb there will either be a flt plate that can be removed to access bulb or where the wires enter there will be a round socket that you can twist counter clockwise and remove the bulb socket for bulb replacement. hope this helps.
1helpful
How do I replace the license plate bulbs?
The license plate lights are accessed by unscrewing the lens. The backup lightbulbs are accessed with the trunk lid open, behind the cover.
5helpful
How do I change the rear license plate light bulbs?
License Plate Lights Removal & Installation License plate lamp retainer clips
To Remove:
Remove or disconnect the following:
  1. License plate
  2. Pin-type retainers and the luggage compartment lid trim panel
  3. License plate lamp electrical connector
  4. Lamp socket from the license plate lamp
  5. Using a suitable tool, through the access hole, release the clips and remove the license plate lamp
To Install:
  1. Install or connect the following:
  2. License plate lamp
  3. Lamp socket to the license plate lamp
  4. Electrical connector
  5. Luggage compartment lid trim panel
  6. License plate
3helpful
3answers
Licence light replacement 1996 Cadillac Deville
remove your license and behind it you will find i think two screws then remove that panel and you should be able to get to it.
Burned out license plate bulb
open trunk,
remove felt liner from rear of trunk, (liner directly behind rear lights in side trunk) should be 4 plastic Phillips head screws. Loosing screws, then slowly peel liner away. You will see 3 nuts on each side, removing these nuts will loosing the rear light lenses, so you can pull the lense away from the body from the out side to gain access to the license plate bulbs. Re-install in reverse order. While in there I would recommend replacing your brake light and reverse light bulb. Hey your already in there might as well do a little preventive maintance.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
