Kurio Touch 4S Handheld Logo
A'sha Allen Posted on Feb 22, 2018
Can my screen be fixed its frozen white dude to water damage. my kurio still charges and powers on its just the screen that doesn't work properly.
If i press down hard on the screen it will appear but has numerous lines of every color appearing and flickering on the screen. There is also a small black dot on the screen. it has been a few weeks since the water damage occurred and i was completely unaware of it until a few days ago.
2answers
How to Fix Kindle Paperwhite Frozen on Lock Screen?
Oops, are you troubleshooting the Kindle Paperwhite Screen Frozen problem? Have you tried all the possible ways to solve this difficulty? Not to worry, if the steps you perform don't work, we are here with some fully searched solutions that will help you to overcome Kindle Paperwhite Frozen on Lock Screen. Follow the guidelines step by step to get out of Kindle Paperwhite Screen Frozen matter easily on your own.
Steps To Solve Kindle Paperwhite Screen Frozen In Minutes
Charge The Kindle
A very common reason that leads to Kindle Paperwhite Screen frozen is the lower battery. It can be possible that you are facing screen stuck issues as of the empty or uncharged battery.
So, to let your device work properly you have to charge it first. Hopefully, charging your device will help you to overcome Screen frozen on Kindle.
Uninstall Corrupted File
If you have downloaded a wrong or corrupted file then you are definitely going through with Kindle paperwhite frozen on lock screen as well as scattering issues with Kindle.
Kindly uninstall the corrupted file as quickly as you can do, otherwise, it will cause damage to your device.
2answers
My kurio talbets has a white face
Press and hold the reset button on your tablet for 40 seconds and then re-press. See if that helps.
My Kurio wont turn on. It has a black screen even when fully charged.
hook it to computer and go to the kurio site and have them diagnose it or they will send you a box to send it to them to be fixed or replaced,tell them its less than 9 months old
2helpful
3answers
My sons kurio 10s has stopped working stuck on smiley face screen how can i fix it
Post an answer to this question...Dear Brandy
Pl long press power switch to make it OFF. then take memory card or sim card from the set. Then power ON if it open go to setting to factory reset and make it rest. Since more applications crunches the RAM and freeze often happen. try to load or move the application to the memory card if any. this will save tabs internal memory.
If problem not solved take to the service center.
thanks
How to fix kurio 7 after dropped in water?
This is probably water damaged. You MIGHT get lucky with keeping it (powered off) in a bag of rice to wick the moisture out of the tablet and into the rice. Keep it there for a few days to keep it from getting damaged any further.
2answers
Once i charge the kurio the screen comes on with the smiley face and thats it
Sounds like the "frozen screen" issue. Hold the on/off button of the tablet well also pressing the Volume+. This should FIX it and unfreeze the screen.
LindaSView
1helpful
Kurio 7S Tablet is 3 days old; it is frozen on the App Menu Screen; cannot turn the device off; cannot do anything; it is frozen and has been for 30 minutes
Typically if you hold the power button down for about 20 seconds the tablet will restart. Some tablets will have a pin sized hole on the back that is a reset button.
4helpful
2answers
Cannot power on my kurio 7 tablet
power up/down
homekey
long press Homebutton
Kurio kids tablet is froze
Kurio won't come off blank screen, i've used the reset button, and the power with volume+ button and it's still the little kurio guy making the smiley face. i took the cover off, it's not hot. Any other suggestions as to re-boot it?
37helpful
9answers
Kurio LCD screen broken
can the kurio 7 screen be fixed if i have broken ( line down the middle of screen and not geting anything picture wise)
Top Kurio Tablets & eReaders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Kurio Tablet and eReader Expert? Answer questions, earn points and help others
