Cars & Trucks Logo
Roxaneking Posted on Apr 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gti 1.8T AGU wont start but my engine vaulves is replaced new after fiting the cylinder head the engine will not turn when im trying to turn it by hand
johnny rebel
Level 3:
Top Expert:
  • Volkswagen Master 10,875 Answers
  • Posted on Apr 08, 2015
 johnny rebel
Volkswagen Master
Level 3:
Top Expert:
Answers
10875
Questions
0
Helped
2938480
Points
47944
Motor is seized,go to a mechanic
5 Related Answers
Anonymous
  • 93 Answers
  • Posted on Dec 09, 2008
SOURCE: i just replaced cylinder head and now my car wont start up
Is timing correct?
First make sure you are getting spark.
Some questions you need to know are what year head is the LS. Did you use the LS Intake manifold and throttle body. Problem is if you didnt use a OBD1 LS and it is OBD2 or OBD0 The Throttle position sensor wont allow the engine to start. Same with the Distributor, because your crank angle position sensor is in your distributor and a OBD1 ECU can communicate withe OBD0 or OBD2
If it is all OBD1 Then I would do a compression and Cyl. Leak down test.
Anonymous
  • 2317 Answers
  • Posted on May 07, 2010
SOURCE: I have a 1987 VW Golf GTI, im trying to reconnect
Green/blue to negative side of the coil, yellow to the positive side of the coil.
daves944
Dave C
  • 1050 Answers
  • Posted on Jan 09, 2011
SOURCE: Im looking for a wiring diagram for the engine
Hopefully this works. I tried to upload the factory diagrams to this site. You have to piece them together after you print them and use the legends. Aftermarket diagrams are better but these will work if you're patient.
http://min.us/mvgcbn0#1
Anonymous
  • 4044 Answers
  • Posted on Mar 21, 2011
SOURCE: Engine cut off when boost
I normally start with the Crank Position sensor or Cam position sensor when this comes up if new plugs and wires don't fix the problems.
Anonymous
  • 20 Answers
  • Posted on Apr 15, 2011
SOURCE: replaced head gasket now engine
Typically this has to do with timing, check the timing
Testimonial: "exactly was the problem "
1helpful
Where is the fuel injector relay on a 2004 vw gti 2.8 liter 24 valve 6 cylinder?
check the immobilizer as it may be preventing the ECM to allow fuel past the injectors
run the fault codes and it could be the ECM needs resetting using a scan tool
1helpful
2answers
1.8l 4 cylinder wont fire after replacing head cylinder?
rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Our 2002 vw gti 4 cylinder doesnt want to start. there is oil around the spark plug cylinder and the car turns over. We changed the crankshaft sensor a week ago due to it dying out, the problem actually...
Take the distributor cap off, crank the engine, see if the rotor turns.
Put it back together.
Remove the center ignition wire from the distributor cap, put the end of the wire within a quarter inch from metal ground, crank the engine, look for a spark.
The engine needs compassion, fuel, and spark to run. Check one thing at a time
2helpful
Im looking for a wiring diagram for the engine management system for a 2000 VW Golf GTI 1.8T 20V AGU??
My key wont turn and the steerring lock is stuck on
The malibus grand ams and aleros all had the same problem. you are going to need to replace the ign cylinder. You may be able to turn the key by lightly taping the end of the key with a hammer and turning at the same time. If you do get it to turn go get a cylinder from the dealer replace the cylinder. You have to program the theft. When you replace the cylinder try to start the car and leave the key in the on postion untill the the theft light goes out and you shopuld be fine.
2answers
Golf mk 4 gti turbo starts up but wont rev past 2000rpm
turbo is malfunctioning the turbo waste gate is not working take it to a shop right away, preferablly tow it so as not to damage the engine, if the exhaust gas's gets near the turbine bearings you will burn up the engine and the turbo cna explode like a hand granade and destrou your enging.
1helpful
Engine vibration
The vibration like comes from a misfiring cylinder when cold, which in turn can have many causes; bad spark plug, bad coil, bad fuel injector, leaking head gasket etc.
With such a major overhaul that you did recently I'd go back to the shop since it can be related to the repair. This is especially true if you see white smoke from the tail pipe.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
