After changing paper in our OCE TDS 400 printer, somehow our printer now sets all prints as a portrait format. I think a setting inadvertently got changed in our printer, but I cannot find a setting to allow it to automatically switch to the appropriate format, i.e. landscape/portrait, which is how I believe it was set previously.
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
SOURCE: cant switch frome landscape to portrait (ipf8000)
try to use the conserve paper option in page set up tab.
SOURCE: my sp 35 printer prints the card in portrait
Maybe you need change page orientation direct on the software that you use for print and design your cards.
SOURCE: Printer doesnt print in the right format, even the
check for dirver setting for paper selected and application setting for paper should be same and try with the costum paper size for the same
select small paper and check printing
SOURCE: 1. The printer is printing everything in
1. You could try to reinstall the Z2420 driver on your computer.
2. Try to reset the wireless network adapter of your printer. Follow the instructions in this article from the Lexmark website on How to Reset the Internal Network Adapter on Lexmark Z2400 Series Printers. Open Lexmark Wireless Setup Utility to reconfigure your printer to connect to your wireless network.
Thanks.
