2001 Hyundai Sonata Logo
First Last Posted on Apr 05, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where is routing belt located on Hyundai Sonata 2001 Alternator?
David Burbee
Level 3:
  • Hyundai Master 1,871 Answers
  • Posted on Apr 05, 2015
David Burbee
Hyundai Master
Level 3:
Answers
1871
Questions
Helped
1056793
Points
1009
I believe you are referring too the Accessory Drive Belt for the Alternator...See attached drawing
Where is routing belt located on Hyundai Sonata 20 - 25629874-2mhejhdcommskt1vzkafo1v3-3-0.gif To Remove:
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2answers
What is the belt routing for a 2007 Hyundai sonata 2.4 liter
I found it and im sending it IF it doesn't show up go to =auto zone and list your vehicle ,under my vehicles, (its free)then go to repair help then to specifications then to belt routing , I hope you get it .if this is a help to you let me know .
Woody
2helpful
2answers
How to bypass the ac pulley on a 2003 hyundai sonata
You can bypass the ac compressor by using a 82" belt. Feed the belt from the back of the engine at the water pump. Disconnect the power steering line at pump. It's a lot easier if you use some type of hook to hold/maneuver the belt. (I used a bent rebar) Follow this routing diagram I created. Bam! No more ac problems!
2helpful
WHERE IS THE SERPENTINE BELT LOCATED ON A 2003 HYUNDAI SONATA
Vehicles Covered: Hyundai Sonata 2002-2004 (2.4L & 2.7L Engines)
In 2003, Hyundai produced two types of Sonata:
Available engines:
4 Cylinders 2.4L VIN "S", MFI DOHC - see Figures 1 and 3.
6 Cylinders 2.7L VIN "H", MFI DOHC - see Figures 2 and 3.
To differentiate between these types of 2003 Hyundai Sonatas, the VIN 8th digit (Engine Type) will either be "S" or "H" as in the table above.
To locate the Engine drive belt, jack up the vehicle & place it onto jack stands, then slide under the car (toss a cardboard mat down first), then, once under the car, remove the (plastic) engine splash shield. Once removed, the drive & accessory belts are easily observed.
Fig. 1 Accessory Drive Belt Routing 2.4L (4 cyl) Engine - Hyundai Sonata
The "COMPRESSOR" refers to the A/C compressor, and "GENERATOR" refers to the Alternator.
Fig. 2 Accessory Drive Belt Routing 2.7L (6 cyl) Engine - Hyundai Sonata
The Belt Routing on the Left is "With A/C", on the Right is "without A/C"
Inspection - Drivebelt and Accessory Belts
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. Worn or damaged drive belts should be replaced.
Drivebelt Removal & Installation - 2003 Sonata (2.4L and 2.7L engines)
To install:
Lower the vehicle.
Here's the best illustration I can find of the Hyundai 2.4L and 2.7L engines - the drivebelt seems to be located on the passenger side of both of these transversely mounted engines.
Fig. 3 Hyundai 2.4L and 2.7L engines - Underhood sensor locations 2002-2004 only
Glossary of Acronyms
A/C - Air Conditioning
DOHC - Dual Overhead Cam
MFI - Multi-port Fuel Injection
2answers
5helpful
Im looking for a serpentine belt routing diagram for a 2001 hyundai sonata
CLICK on the following LINK. It has the Serpentine Belt Diagrams you will need.
If you would: Before Clicking let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2001/make/hyundai/model/sonata/2001_hyundai_sonata_drive_belt_routing_diagram.htm
10helpful
2answers
How do i remove a belt from a 2001 hyundai xg300 car
To install:
Accessory drive belt routing—1.5L engine
Accessory drive belt routing—2.0L engines
Accessory drive belt routing—2.4L engines
Accessory drive belt routing—2.5L and 2.7L engines
Accessory drive belt routing—3.0L and 3.5L engine
I have a 2001 hyundai sonata and the belt broke. i tried to replace the belt but i cannot seems to get it on i removed the top alternator bit and loosend up the bottom one i got about a inch or so but...
I do not have the specific data on this car but look at the tensioner carefully to see if there is a square cutout where you can insert a ratchet or it might be a spanner. Apply pressure as if tightening or loosening it, it should move quite a bit so the belt can be installed. If it does, put back everything together, route on the belt over and around the pulleys (look at diagram for car). Pull or push forcefully on the tensioner and slip on the belt. You can use a piece of pipe over the ratchet for leaverage. Make sure the engine is cold and be careful not to scrape your knuckles. Let me know what you find out. Hope I can help.
2helpful
Can an Alternator Belt installation cause a timing belt problem?
I cannot see any reason for the belt to cause timing belt to jump. unless they messed up something installing belt.might wanna get a second opinion
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
