Televison & Video Logo
Question about Lite On Televison & Video
I have had a LiteOn LVW-5026 DVD recorder for 5 years or so and have not had any problems till now. I bought some blank Verbatim DVD+RW discs but found the recorder would not recognise them (ie, prepare disc for copy). I decided to buy my usual Phillips DVD+RW's again but now the recorder does not seem to recognise these either! It does however, recognise discs that have already got recordings on.
Posted by tjwarnes on
  • tjwarnes Jul 11, 2009
    What do you need clarifying ? My question or where to get Lite On DVD recorders ?
  • jim_mccullie May 11, 2010
    I have liteon DVD recorder Lvw-5005 Lvw--5001 i wish to buy two more where can iget them.
5 Related Answers
Anonymous
SOURCE: Liteon LVW-5045gDL+ dvd recorder will not burn to blank dvds
SAME HERE. I Have tryed a lens cleaner and seems to be working at the moment
Posted on Jan 15, 2008
Anonymous
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
Posted on May 10, 2008
Anonymous
  • 13 Answers
SOURCE: LITEON LVW 511GHC
Go to Lite-on and download the manual in pdf format. You will need Adobe Reader or something similar. Here is the link:
http://www.liteonit.com/DOWNLOADS/DC/LVW-5115GHC+/firmware/us/LNMPU030.zip
Posted on May 19, 2008
junroedi
  • 5 Answers
SOURCE: liteon lvw-5045
it maybe the spindle motor that rotates the disc thats why there is no information read by the laser or the laser itself is the problem. if it is only the motor it can be replace but the laser it should be compatible or the same model. one simple thing to do open and try to clean the optical lens by a cotton buds gently rub around the lens and close and try.
Posted on Jun 10, 2008
Anonymous
SOURCE: My Liteon LVW-1105HC DVD recorder
I had the same problem, I had to open up the covers (including the one covering the lens) and clean the lens with a soft cloth. Please be very careful while cleaning the lens since it is very delicate and any damage would permanently disable read/writes.
Posted on Dec 16, 2009
What do + and _ signs mean on blank dvds
- RecordNow! can record only to the same disc type
it records from. For example, you can record a
DVD only to a DVD+R or DVD+RW disc, and you
can record a CD only to a CD-R or a CD-RW disc.
you were using DVD-R, so it won't work.
hope this helps
My LiteOn LVW-1101 Erasing DVD's Hi, Hope you can help me with this problem as Im not techically minded? I own a LiteOn LVW-1105HC and after recording DVD's(even DVDR's) I put the disc back in to...
Your lite on has lost its mind and needs replacement.
Meanwhile a non rewritable disk cannot be erased. If not finalized it may not be read on another machine but the originating machine can read it.
1helpful
2answers
I recently have not been able to record on DVD+RW discs. An error message keeps coming up saying it cannot record on this disc.The dumb part about it is I still have a couple of discs of the same nature...
According to the user's manual, for DVD+RW or DVD-RW discs, it may take some time for the disc to be recognized and then it has to format the disc prior to using it. This should be an automatic process when the disc is inserted (looking at page 17 of the owner's manual). If this is not happening, you may need to clean the DVD with a DVD cleaner (a DVD disc with tiny brushes that wipe the lense on the unit while the disc spins). You could first try using a can of compressed air and blowing any dust/dirt out of the DVD slot (with the tray open).
Where can I get repaired in India LiteOn DVD Recorder ?
There is no ,LiteOn authorised repair centre in India. You can get in touch with a local repair technician for the same . Alternatively you send Liteon support people an email. Incase they have a tieup with an indian service & repair company.They would let you know.Find the link below
http://www.liteonit.com/global/index.php?option=com_wrapper&Itemid=70
Thanks for using fixya
Proton
1helpful
Liteon LVW-5005 DVD Recorder. Disk drive door will not open.
give it a tap on the bottom as you press the button, this will force it to release the disc,
Unreadable disk error
The laser in 5101 could be defective or maybe just dirty.Try cleaning with a commercial cleaning disc,put a drop of rubbing alcohol on cleaning brushes.When this happens sometimes it will still be a usable disc but not always.Try putting in another dvd player or recorder or your PC if it plays dvds,the readers in PC are of a better quality and will often read discs that those cheap dvd readers can't.
R+ or R- discs need to finalized after recording RW+and RW- discs do not.It is always a good policy to finalze the second your recording is finished otherwise it may not play in other players or recorders.
When you make a recording in a dvd recorder an it doensn't recognize the disc it just recorded it quite often has a defective laser.This particular model has been plagued with early laser failure.
6helpful
3answers
Oct 09, 2007 • iLO DVDR04
8helpful
5answers
Lite-On LVW-5005 (DDW-813s)
I have same problem like you, but I have changed the DDW-813s to a new Lite-On DH-20A4P, it work perfectly, good as new. but you have to make some changes to fix it to the place
2answers
Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Top Lite On Televison & Video Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
