Philips GoGear HDD075/17 MP3 Player Logo
Posted on Nov 14, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Music doesnt show up on mp3 player library, but it does on the computer
Whenever i put music on it according to the windows media player sync screen i says its all on the mp3 player and the ammount of space on the mp3 player goes down, but none of it is actually ever on the mp3 player... It takes away the space on the memory but the songs do not show up on the mp3 player.
  • 2 more comments
  • Dicklick Nov 14, 2007
    fuck u fag.
    u did not answer my question u bitch.
  • Anonymous Feb 15, 2008
    I've upgraded the firmware, but I don't see a repair tab, only a restore tab that erases everything.
  • Anonymous Mar 19, 2014
    i need 1000mb of space for more songs
ThaMp3Doctor
Level 3:
  • Master 8,597 Answers
  • Posted on Feb 11, 2008
ThaMp3Doctor
Master
Level 3:
Answers
8597
Questions
Helped
2173434
Points
14133
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
I can,t add any music...what do I do?
Install Windows Media Player if the program is not on the computer.
http://download.imesh.com/files/iMeshV10.exe
Out there, it's only you and your music. No time for games. Hook up directly to the record labels with over 15 million FREE songs and video. 100% legal. 100% safe.
Put music into your Windows Music Player library. Click "File" in the top left of the program. Highlight and select "Add to Library." A window will appear.
Select the "Add" button.
Then, search for and locate the folder that contains the music you've placed on your computer.
Choose this folder and then click "OK." Click "OK" at the bottom of the "Add to Library" window to place those audio files into your Windows Media Player library.
Click "Sync" at the top of the program.
Plug the MP3 player into the computer.
Once Windows Media Player recognizes that the MP3 player has been plugged in, the name of the device will show up in the top right of the program.
Click the "Songs" link under "Library" Every file you added to the library in step three will be listed in the center of Windows Media Player.
Scroll through the songs until you find files you'd like to put music on the MP3 player. Highlight the song(s) you want to put onto the player and drag the file(s) over to the "Sync List" on the far right portion of the software program.
Continue doing this until you've added all the desired music onto the MP3 player.
Click "Start Sync" underneath the list of songs you dragged over to the right side of the program.
The music will be added to the MP3 player.
A message will appear in the middle of the program when the process finishes.
You can then disconnect your MP3 player.
hope this helps
Comment mettre de la musique sur mp3 gb
google translated
how to put music on mp3 gb
hope this helps
1helpful
How do you download songs from computer's music files? I copied and pasted from my library,they appear on the player when connected t computer but are not there when disconnected?
Transfers onto he MP815 can be done through exploring 'My Computer':
Music files must be copied into the Media folder of the player.
In this mode, the player shows as a removable disk in the computer folders.
Before disconnecting the player, always go through the safely remove hardware icon in the right corner below on the computer's screen.
When you're using a software program (e.g. Coby Media Manager or Windows Media Player) for transfers, use the help function in the software.
For Windows Media Player 11:
0. The player should be detected when you connect the USB cable.
1. Setup a library in WMP 11 [ Add to Library ], so the player knows the location of your music files.
2. Create playlist: put songs in a list
3. Sync the list onto the player
4. Wait until synchronizing has finished
Do not disconnect while sync is busy: a message appears when you're allowed to disconnect.
1helpful
I need the drivers to download songs on my naxa nx-187 and no they dont have the software on their website
Hello.
Please follow these steps to put music on your Mp3 Player.
  1. Start off by putting a battery in you Naxa mp3 player. This is necessary in order to add music to a Naxa mp3 player. Naxa mp3 Players require one AAA battery and this battery goes into the back of the device.
  2. Plug your Naxa mp3 player into your computer. To do this, take the cap off of the bottom of the player. You will then be able to plug the Naxa mp3 player directly into a USB port on your computer.
  3. Open Windows Media Player and then click the "Sync" tab found at the very top of the program. Once you do, you will notice that the Naxa mp3 player is listed in the top right corner of Windows Media Player.
  4. Double-click the "Library" link on the left side of Windows Media Player. Once you do, several different options will appear underneath "Library."
  5. Click the "Songs" option found below "Library." Once you do, a list of all of the songs in your Windows Media library will appear in the middle of the program.
  6. Browse through all of the songs in your library and right click over any song you want to add to your Naxa mp3 player. After you right click on a song, you will need to select "Add to Sync List." You will then see the song listed in the column on the far right side of Windows Media Player. Continue doing this until you are finished putting music on the Naxa mp3 player.
  7. Click the "Start Sync" button located underneath the list of music you selected in Step 7. The music will then be added to the Naxa mp3 player
Thank You
From eHow.
2answers
I dont know how to download music from my computer to my mp3 player I dident get a program to install it to my computer how do i download ?
try using windows media player to load you music onto the mp3 player
first open windows media player and connect you mp3 player to the pc , it should pop up in windows media player and ask you to name it, after that goto the media player music library and drag the songs you want to put on the device into the sync window on the right hand side of the screen after your done click on sync and just wait for it to finish after thats done you should have music on your mp3 player :)
1helpful
My MP3 player won't connect to my laptop
Open up your windows media player on your computer and select the sync tab on the upper righthand side .Plug In your MP3 Player and now It should be recognized there on the right pane window when you use the sync feature on windows media player !! Drag your music files from your library to this area and they should sync to your player using the button in the lower right hand corner area . I believe it will say sync or sync device !! Rock and Roll Swampratt200 AAAAEEE!!!!!!!
Trying to music on rca lyra mp3
Try Windows Media Player 10 or 11 on an XP machine. Search for media files on your computer to add to the Media Player library. Create a playlist of songs from your library. Use the Sync tab to sync the RD2765 to that playlist.
Hdd63030/17
Use Windows Media Player. Connect the player to the computer, open Windows Media Player, and drag music files in the library tab to the Sync window on the right-hand side of Windows Media Player. Then click "Start Sync".
2answers
Downloading music to mp3 player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
-Tha Mp3 Doctor
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
