I am curious whether the Nissan Frontier CD Player is capable of playing MP3 audio disks. It used to be a big deal for a CD player to be able to play MP3s but I'm hoping most have that capability now.
I was able to burn a CD with 55 songs on it in MP3 format and it played perfectly in the Nissan Frontier! So I answered my own question.I was able to burn a CD with 55 songs on it in MP3 format and it played perfectly in the Nissan Frontier! So I answered my own question.
You can't post conmments that contain an email address.
you said CAN , i bet you meant CAN'T or CAN NOT. right?
the AUX port is just a line input, analog audio input,
it dont know MP3 .
it only amplies the analog audio found there.
you connect any device, to AUX. push play on the device.
then put car radio in to AUX input mode and play. the audio.
that is all there is to it.
the external device does all the heavy lifting, reading a file, and decoding it (mp3 decode) and then sends raw analog audio out.
the cable is sold and radioshack, or walfart or many other stores,
Target, most MP3 players, come with this cable,
they use mini phone plugs, stereo, type,. (3 contacts)
as the cd player has no servicable parts for you to play with,when they go wrong they go in the bin.how about converting all your cd s
to mp3 and buying an fm transmitter, then you can play your whole cd collection on any fm radio.think santana in your mums car.......
get an aftermarket deck. If you don't have the bose system, the OEM non bose does NOT play mp3 cds. It only plays audio cds or burned audio cds. It does have the aux jack if you hook up an mp3 player or your iphone/android phone to play Pandora using a headphone cable.
you may have set the cd burn onto mp3 instead of audio cd... if you're using a program like itunes, you can determine the output to be mp3 or cd audio... hope that helps...
The "read-ahead" memory cache is too short.
Not much you can do, short of replacing the player; however:
Does your CD player support playing MP3's?
Convert your Audio music CD's to MP3.
The same audio music is "smaller" in MP3 format than audio format. More of the song can fit in the memory cache so it is less likely to "run out" of mermory and skip.
I was told the in dash radio unit will not play mp3's. as far as the dvd player, if you have the entertainment system i can't say. I do have two solutions for you.
1) the in dash cd player (mine is a 6 disc cd player) will not play mp3's at 128 bit compression, but for some reason or another I burnt an mp3 disc using the 256 bit compression, still smaller than the standard mp3 comparable cd quality, and unknowingly tried it in the cd player. The nissan quest played it. So it sounds as if the cd player is picky about how low quality of an mp3. 128 is a common reasonable quality. However, I was able to squeeze about 15 tracks on a 256 bit mp3 disc.
2) the in car dvd unit. If your unit is of the standard type, under the seat or mounted elswhere in the car, you could replace it. Dvd players sell for around $125.00+ and will play everything under the sun. reconnecting is not the biggest challenge neither.
& 3) You could purchase an additional hardwired device which allows you to plug in any audio device and play the sound through the Nissans sound system. The device into plugs directly into your wiring loom behind your factory radio. The best part is that the nissan system is already set up to receive this device. It will play through the sat1 or sat2 buttons. I searched and purchased the device online.
i had installed that before learning of the mp3 deal.
well good luck.
Sincerely, Flash
