Question about Maytag Neptune MAH5500B Front Load Washer
Maytag MAH5500 - Washer won't shut off
Washer won't shut off - The washer runs through all the cycles normally but doesn't shut off at the end. The door remains locked, the washer remains on and it rotates every 30 seconds or so. I have to push the Start/Stop switch to shut it down. Does anyone have an idea what might be causing this?
Posted by FVRacer on
  • 6 more comments
  • Anonymous Nov 21, 2007
    I have the same problem as the one described here. I have checked the timer and when it is at the "off" position, all contacts are open. I have looked at the schematic but am not sure where to go from here.
  • Momadams Nov 29, 2007
    Mine's the MAH4000 and just started doing this.
  • Anonymous Aug 19, 2008
    door isn't locked on my machine and all water is completely gone, clothes have spun out nicely (almost dry) just replaced wax motor and main circuit board.
  • Paula Falzarano Aug 19, 2008
    my problem is that My machien runs through all cycles and finishes but just won't turn off, clothes are nicley spun out.
  • Jordan Melick
    Jordan Melick Sep 15, 2008
    I have the same identical problem with my Maytag Neptune MAH4000.  Everything else functions correctly.
    Is it the TIMER or Machine Control Microprocessor Board that is failing?
    Thanks!
  • Anonymous Feb 12, 2009
    washer runs with "nf" in the display, light cycle has grown by 15 or more minutes over time
  • Anonymous Apr 14, 2009
    Exactly the same problem for a 20 year old MAH3300.
  • Anonymous Mar 25, 2014
    Washer door will not lock causing the washer not to start.
Anonymous
    Champion:
  • 249 Answers
Make sure machine is pumping out fully
Posted on Nov 24, 2007
My maytag mah5500 door fails to lock and wont drain
Press "end of cycle" to get machine to normal. Then plug off the wall. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Oct 18, 2015 | Maytag Neptune MAH5500B Front Load Washer
Door won't open
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/27966-maytag-mah5500b-fl-code-door-locked.html
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/13490-maytag-neptune-mah5500-wont-open.html
Dec 31, 2012 | Maytag Neptune MAH5500B Front Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Maytag navigator washer not draining all the water out
Here are some things for you to check out
Please read fully this covers a couple of different brands but it is all the same things to check ok?
When the clothes are wet at the end of a cycle, check these:
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jun 23, 2011 | Maytag Washing Machines
Maytag Neptune Washer, Model: MAH5500
The problem is with your door lock set.You may need to
replace it.If your lock is faulty the washer wont begin its
cycle.
Apr 08, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH4000 - Washer won't shut off!
sounds like to me you have a bad board needs to be changed
Sep 16, 2008 | Maytag Neptune MAH5500B Front Load Washer
Cycle runs normally but the washer does not stop after spin
I don't know specifically about your machine but I think the problem is with the door lock. Again, on most machines with a shakeout it can go on and on until the door unlocks. Does your machine have a door UNLOCKING solenoid or does the door lock just lose power at the end of the cycle. It may be that you just have a very weak solenoid to unlock the door.
Feb 18, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
449 people viewed this question
Top Maytag Washing Machines Experts
John Tripp
John Tripp
jdthefixer
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
