VERY loud noises might indicate a loose counter weight. Open the cabinet then raise the top and check the condition of the counterweights and that they are fastened down properly. The front lower counterweight is held on at the ends by two lugs connected by a formed rebar rod and a spaced bolt in the middle of it. Check these first. Loose you can fix. If the rebar breaks, the counterweight will beat the inside of the machine up pretty good, usually damaging the water pump strainer housing. If this doesn't solve your problem, look at some of the other posts here for other ideas. They're really good.
Regards, --WoobieDog--
