Question about Konica Minolta DiMAGE Z3 Digital Camera
Minolta Dimage Z3
What Flash would you recomend for above camera
Posted by dustyroads on
photomuste
You can use Minolta Maxxum Program Flash 5600 HS, Program Flash 3600 HS or 2500D as a master flash.
But they r some expensive, u can check the prices in ebay.com
Posted on May 07, 2008
Anonymous
  • 138 Answers
You cannot add external flash as far as i know!
Posted on Dec 08, 2007
How to convert my raw images
Photoshop, GIMP, Rawtherapee, Darktable, Lightroom, etc...
You can even do it in batch with linux.
But I recomend to set the camera to jpeg+raw and let the camera do the conversion for you. Then if you need an special retouch of a photo, use any of the above applications.
Feb 23, 2015 | Canon REBEL T2i EOS 550D Digital Camera...
The flash unit will not pop up completely and will not take a flash picture unless it is held up manually.
Most of these types of cameras have a spring on the underside of the flash that either breaks or slips off the connection on one side or the other. You may be able to locate it and slip it back on.
If you are not able to fix it, I'd recomend taking it in to a repair shop. It is a simple repair and covered by warranty. Even out of waaranty it should not cost too much.
Nov 20, 2009 | Fuji FinePix S700 Digital Camera
Flash has broken on DSC S85
Flash Board part number is as follows..
147667311... FLASH UNIT, available in Part Store.
If you are not comfortable with replacing above flash board in DSC-S85, take camera to qualified camera tech because camera will be apart in detail to replace flash board.
Thanks.
Nov 17, 2009 | Sony Cyber-Shot DSC-S85 Digital Camera
Indoor shots such as a wedding
Have you thought about using the flash??? In low light you may not be able to hold the camera steady enough to take pictures without using a tripod.
If you want to change the colour ballance of the camera, look in the user manual. It is a little bit involved. I would recomend using the flash instead.
Jerry G.
Jun 30, 2008 | Sony Alpha DSLR-A100 Digital Camera
Random pictures
Check in the user guid for your camera about their recomended shutter speed setting for the flash.
Try using the camera and the flash in "A" (automatic) to start with.
Jerry G.
Feb 15, 2008 | Nikon Speedlight SB-600 TTL Flash
SB800
When you attach the flas to the camera can exidentli fire. This is normal, and manufacturer recomendation, turn off the flas unit before attach or deattach, prevent this fireing. Fireing when you turn the flashead is not normal. Probably the mounting foot of the flash unit can move in the hotshoe, breaking connections between the connector pins, causing exidental fiering. Always lock the locking lever of the flas, wich can prevent this unwanted movement. Also chek the hotshoe on the camera, wich should to have a "leaf spring" keeping the flash unit steady.
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Problem with slr camera flash obstruction
The problem is in the flash pop up switch. It is probably jammed in or there is some kind of substance on it causing it to stick. You can find it by manually popping up your flash. You should then see a little black spring loaded post on the release button side of the flash. Check to see that it is not stuck in in any way. If so that is why you are getting error 5. To repair you can try a qtip an a little rubbing alcohol. Otherwise you will need a technician to do it.
Dec 04, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Flash not working
the flash bulb or tube does not go off suddenly. it gets weak after yers of usege or breaks only if the camera is dropped. most of the flash related problems occour for non charging of the flash. pls contact local repairer for this problem
Jun 20, 2006 | Casio Exilim EX-Z40 Digital Camera
Problems with sync cords in the studio
Since synch cords are famous for wearing out, perhaps a new one?
Sep 14, 2005 | Canon PowerShot 600 Digital Camera
Flash for 3100Z
I use a Sunpak 433D flash with my Epson 850Z camera. Do a search for vivitar in this forum and you should get a lot of hits.
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
96 people viewed this question
Top Konica Minolta Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
