Hi, perform the following steps to get this issue resolvbed...
1. Check whether the lens cover is opened
2. check whether the battery is fully charged.
If the battery is not fullly charged, connect the Camcorder to the wall outlet using the sipplied AC adaptor.
3. Then, try resetting the Camcorder by pressing the RESET button using a sharp-pointed object while the Camcorder is turned ON.
4. If the issue still persists, turn OFF the Camcorder; then remove the battery pack and discinnect the Ac adaptor from the Camcorder; slide the POWER switch to the ON position for 1 minute. Then, connect the AC Adaptor tro the wall outlet and cjeck whether it helps.
If the issue still persists, service of the unit may require. contact the manufacturer of the Camcorder to get ut serviced.
SOURCE: i need sony DRC-TRV250 CAMCODER
Welcome to FixYa
Dear User
Here is Software and Driver available for your Model.Download it from here...
Hope This HELPED....
Thanks for Connecting FixYa..
SOURCE: i need two drivers, for
Please get it here :
www.vierstra.com/.../download-sony-dvd-handycam-usb-driver/
Regards, Jay
If the issue persists, perform
a power resetting of the Camcorder. To perform power resetting, please remove
the battery pack, turn the Power switch to ON for more than 15 seconds, turn
the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps,
service is required.
