Question about Garden
Selfpropelled string on a toro snapped
The end came off when it snapped. How can this be fixed?
Posted by wilkinsbritt on
Roger Geer
  • 78 Answers
If you are refering to a cable ,it can be repaired by replacing the entire cable. The ends are cast aluminum.
Posted on Oct 29, 2009
Toro 20017 clogs up all the time even if grass is mainly dry.Have moved the height up but still contines to clog
This is not a safe fix,but it works.Tie a string to the top of the chute the grass comes out of.Lift it just a lil and tie off the string.
May 11, 2011 | Toro Lawn Mower With Toro Power Tools
My toro 51970a trimmer has been leaking gas and flooding for the past few weeks, but I could start it. Today, it is gushing gas from the back when I pull the starter string. How do i fix this?
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
Oct 26, 2010 | Toro& Electric String Trimmer
String is wound incorrectly
Hello. Just pushing it back does not fix it. Cut off the excess and then you should be ok again. J.
May 24, 2010 | Toro& Electric String Trimmer
I have replaced the transmission assy. on my toro selfpropelled; the problem I have is I can only get one side to work at a time. With no wheels installed, both of the gears on the front drive spin in the...
Many TORO mowers have a drive pinion that can be used on either side, however, internally, they ratchet one direction, drive the other direction. You may want to rotate (reverse) the installation of one gear and try it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 08, 2009 | Toro Lawn Mower With Toro Power Tools
Broken selfpropell cable. Need to replace
To replace the cable you would have to go to a Toro dealer and purchase tjhe cable I don't know of another way to get the right cable. themn Remove old one and install the new one. There are some universal cables out ther but they can be tricky to adapt to some mowers.
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro GTS5 20482 Pull String Loose
The whole assembly looks like it should be part number 94-1661. Doing an online search for this part should bring back relevant pricing information: http://www.google.com/search?q=94-1661+starter+assembly. Otherwise visit https://homeownersolutions.toro.com/portal/server.pt?open=512&objID=214&PageID=0&cached=true&mode=2 and download the parts catalogue for your mower to get the exact pieces to rebuild the starter assembly.
Pull string broke on crafstman 6.75 mower
when the rope broke you first must rewind sring and load tension on it first then install spring while it is underload clamp with vise grips until string is fed through then release slowly allowing string to recoil
Jul 15, 2009 | Toro Lawn Mower With Toro Power Tools
I need to fix athe pull string on my toro push behind mower. it has an 195cc tecumseh motor. the string broke and i can't find anything on toro about how to fix it without buying the whole assembly.
remove bolts from cover and remove the cover. Should be able to access the assembly for the pull rope. Go to a local mower repair shop buy some new line. The old line should just be knotted up on the spring loaded wheel in there. You put a new piece on put in a new knot, put some turns on the assembly to basically wing the spring so it snaps back when pulled, put line through whole and attach to pull handle.
Jul 11, 2009 | Garden
Need to replace pull string on lawn mower
how do i change the pulling string on my toro 22 recycler
Jun 13, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
