Question about Asko Dryers
I'm trying to replace a broken belt on my Asko T721 dryer, I have removed the back panel and taken out the broken belt but I can't acces the drive shaft to hook the belt on and around the pully, how do I do this, have you any doagrams I could follow. Thanks
Posted by rachel Bryant on
You too
Hi when I replaced the belt on a T721 I opened the back and went in from there. Lay the dryer on the front and remove back screws. Take pictures of all wiring and all assembled. Replace belt and idlers. Note its tight in there and you will need to remove the back fan and housing. I removed the entire from and cleaned everything when doing the change.
Posted on Jul 19, 2019
Jorge Rendon
  • Asko Master
  • 5,420 Answers
Try googling or youtubing it
Posted on Mar 30, 2015
I just replaced the belt on my t721 dryer and a bunch of the wires came off of the relays where can I get a wiring schematic for this machine
Look on the back panel of the unit - not uncommon for a schematic to be there. If not, go to appliancepartspros.com for parts/schematics.
Jul 04, 2015 | Asko Dryers
How do i remove the front panel of the asko t721 to replace a broken belt?
REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
25764946-gtkp3url2ghtdqenstp5bokb-1-2.jpg REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
Jun 29, 2015 | Asko Dryers
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
Asko T721 dryer. Support rollers started to fall to bits (dryer making bumping sound as it rotated) so I bought a new set and replaced them. Not a single electrical connection was removed bar the door...
  • If you took the drum out and took the belt off you may have put the belt on wrong as there is a switch under the drive or idler pulley that must be pushed on from the pressure of the belt on the pulley. Also go and make sure both breakers are ok in the breaker box as it runs on a 220 volt sys. and if one is tripped this type of thing can occur.
  • Good luck and please rate me if this helped! thanks again for choosing fixya
Oct 12, 2010 | Asko T721 Electric Dryer
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Jul 24, 2009 | Asko T721 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Mar 17, 2008 | Asko T721 Electric Dryer
Dryers Logo
567 people viewed this question
Top Asko Dryers Experts
Marvin
Marvin
Paul Carew
peter gittos
peter gittos
Are you an Asko Dryer Expert? Answer questions, earn points and help others
