Have a A200-T Hobart Mixer. There is voltage present on the housing of the unit. Goes away when I remove the ground wire. Found a pinch on the power cord and repaired that. I am still showing voltage on the housing of the mixer
Parts Townhttps://www.partstown.com > HOB-A200_spm
PDF
A200 Mixer 115/60/1 Technical ManualPage 2 of 43 ... Manual Bowl Lift ... If service is needed on this equipment, contact your local Hobart Service Office.
43 pages
Hobart A200 Stand Mixer
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
be careful here as the grease used has to meet food quality requirements and is not car grease
it does not need to be full of grease , just enough to cover the teeth
go google and type in --hobart food mixer model a200 --and there may be a pdf version parts list or workshop manual
other than that there will be a contact number for your country or area where you can get advice
usually 2 wires that AC current goes through. check with volt meter set to ohms test for resistance . if you know the value .of resistance ? but if the machine has power but does not run . you know there is a thermal fuse hidden .once blown it does not reset..so you can throw it away. please don't..just replace the fuse or get a resettable one Radio shack or local electronic store . it is a size of a ADVIL pill with 2 wires inline of power coming in to switch ... >^.^<
How old is the mixer? Could it have a brush style motor?
Easy to tell. It will have a couple of removable panels on the motor rear cover. The brush mount plate may have moved out of position, which retimes the rotor and stator windings. With the power disconected and the rear main cover removed, look at the internal screws for prevoius marks where the position might have been.
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor Start switch (electronic or mechanical) Burned wiring Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Hi Don. If your mixer is hurling honey, you must be very popular in the ant world...Sorry!
The Hobart electric motor on your mixer was designed and engineered to operate on 115-120 volt current and is the most dependable, and capable commercial mixer out there Is it possible for you to use a commercial Imerssion Blender for the first part of your mixing operation. Once your honey thickens a bit perhaps the a200 wouldn't hurl honey. Another consideration would be to either try a different beater or modify the one you have by removing surface area from the beater. If you remove metal, be sure to do it in a balanced fashion to avoid unwanted vibration in the beater. If you're not up to removing metal, take it to a machine shop and they'll do it for you. It probably won't take long, or cost much, and they have the expertise and the equipment to do it properly. If you found this solution helpful, please rate it. Good luck! ricardok45.
grease coming out the planitary on bottom normally means it needs taken apart completley cleaned out of old grease and new seal and newer stile spacer seal goes around with the O-ring on it. and factory grease. the noise impossble from here to tell.
Where is it leaking grease from?Im a hobart tech and service these mixers.When i go into work i will get you the part # for the grease.You would then have to contact your local hobart branch,tell them the part # and pick up the grease.
