Question about Garmin StreetPilot c530 GPS Receiver
Garmin c530 dont know pin or security location for garmin c530
Posted by marcusnobles on
  • marcusnobles Jul 10, 2009
Anonymous
  • 333 Answers
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Posted on Sep 15, 2009
  • 2 more comments
  • Anonymous Sep 15, 2009
  • Anonymous Sep 20, 2009
  • Anonymous Sep 21, 2009
TO Lady
  • Garmin Master
  • 638 Answers
You'll have to send it back to Garmin with the original receipt from an authorized Garmin dealer. Garmin will then reset the password. No receipt? No reset. This is a security feature on the Garmin units to prevent use in case of theft.
Posted on Mar 04, 2010
I forgot my pin number and my device is locked
You would have to go with-in 50 meters of the Security Location you set up your unit....that could be your home or office.... you had to call Garmin to Register the unit,when you did it set that location as a security spot.
Once there it will automatically unlock for you, dont forget to enter new pin number before you leave that area.... if you dont know where it was at, you must send the unit back to Garmin with proper receipts.
FYI
Dont set your security location as your home, thiefs will know and change it so they could now have a working gps
Nov 02, 2010 | Garmin StreetPilot c550 GPS Receiver
Nuvi® 255W Car GPS Receiver: i have a garmin nuvi 255w and its locked and need ...
I had for 2 years a nuvi 255w and its as working real good. Until one day i tried to open it up and it ask me a code pin. Witch i dont have. Ive been the only one owner on that GPS and never put any pin code on it and now just like that it want one... Grrrr that **** me off i cant use it anymore i dont have any acess anywhere exept that pin code of 4 number,. Is this possibility of update? I dont know I am the only one in that situation?
May 16, 2010 | Garmin nuvi 255W GPS Receiver
Garmin c530
You have a problem only Garmin can solve, unless you remember your pin or go back to where you set the security location
Apr 04, 2010 | Garmin StreetPilot c530 GPS Receiver
My 3 years old son has unlock my Garmin GPS, and it is asking for PIN now. How can i unlock it? is there any master PIN
No, there is no master PIN but if you take it back to the security location you set when you first installed the GPS, it will automatically unlock and you can then reset the PIN number.
Dec 23, 2009 | Garmin StreetPilot c530 GPS Receiver
I purchased a used locked Garmin c530 gps and I don't have the pin # to unlock it.Is there a way to unlock it.Thankyou
you will have to ask the previous owner for the lock code. if he doesn't know it, get you money back from him. the only way to unlock a garmin is to know which location the code was first programmed in or by sending it back to garmin with proof of purchase. this is an anti-theft feature.
Nov 10, 2009 | Garmin StreetPilot c530 GPS Receiver
Help me unlock my gps i do not remember my pin # all i can remember is there is 6 # in the pin please help me
Take it back to the 'secure location' as indicated in your service manual. It will automatically unlock when it gets a full satellite signal. You have to enter the PIN number twice when setting up the unit. You should always use a number which is familiar to you so you can remember it. If you can't remember it, and if your secure location doesn't unlock the unit, you will need to send the unit to Garmin to unlock it. You will need your receipt for Garmin to unlock the unit.
May 31, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin C530 need pin to unlock
Have you tried putting the unlock code in the main directory?  To do this open up notepad or some similar text program and copy the code from the yellow sheet onto the note pad and save it as GMAPPROM.UNL.  Then open "My Computer" and locate the Garmin removable device.  Open the "Garmin" folder and copy that file to it.  Safely remove it from your system and turn it on.
Nov 18, 2008 | Garmin StreetPilot c530 GPS Receiver
Pin Removal
To reset, you have to go to the home location. That is the security location.
The only other solution to unlock this model GPS is to send it to Garmin with the proof of purchase. They are the only ones who can unlock your GPS. If you read the instruction booklet that came with the GPS, they expain the same thing I am indicating here. Call the Garmin support for details.
Jerry G.
Jun 25, 2008 | Garmin nuvi 200W GPS Receiver
Reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
Feb 21, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
500 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Tom Chichester
Are you a Garmin GPS Expert? Answer questions, earn points and help others
