SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
SOURCE: troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
SOURCE: How do you add trimmer line to Troy Bilt TB539E
This model trimmer uses .095" diameter line, your local home improvement store will carry replacement line and it will also carry a replacement spool with the line already spooled on it.
This trimmer is a "bump advance" trimmer meaning you bump the head on the ground while it is spinning to advance line out.
What to do to replace the line is place the trimmer on a stable flat surface (like a workbench), raise up the head if the trimmer and unscrew the cap and CAREFULLY remove the spool...you do not want to lose the spring! Take a look at the spool, it will show the direction to spool the line, spool the line then replace the spool by first putting the spring back on the shaft, then put the end of the line through the hole(s) on the side of the outer head, press the spool in place and screw the cap back on.
Of course you can eliminate about 90% of the headaches by buying a pre-spooled head at your local home improvement store...then you follow the directions above and can skip the spooling part. Cheers!
SOURCE: Need info on putting line on troy bilt 4-cycle
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
SOURCE: Cannot restring Troy-Bilt weed trimmer
On the directions below tells you how to restring the spool.
If you can not read it you can click on the link below to download the manual.
http://manuals.mtdproducts.com/mtd/GetFile.do?filename=769-04481.pdf
If you have any questions please ask befor you rate.
Good Luck
