Question about Health & Beauty
How do I check the battery charger to see if it is functioning properly
P/N A24040-IL-EMI MODEL AE244000 If I take it out of the scooter to troubleshoot it, do I have to short pins together, etc. to get an output from it?
Posted by Timothy J Black on
ADRIAN
    Sergeant:
  • 313 Answers
Some chargers need to be connected to the batteries before they turn on the charge current. With the charger connected and switched on, check the voltage across the batteries and should be about 26 volts for a 24 volt system. And you can use an amp clamp meter for current flow.
WARNING
DO NOT SHORT PINS TOGETHER
Posted on Jun 17, 2015
5 Related Answers
Anonymous
  • 26 Answers
SOURCE: wont charge
the batteries have failed or the fuse in the charger
ted
Posted on Apr 15, 2010
Neil Wood
  • 177 Answers
SOURCE: InvaMed Sovereign Mobility Scooter Model S888NR
Hi. Its easy to identify the pins out. Put the probes into the socket on the scooter to read the polarity. the two terminals on opposite sides will be the positive and negative battery supply. The pin to one side is to disable the scooter when the charger is connected. This terminal is normally connected to negative when the charger socket is in place.
Most faults like this are caused by a broken wire in the charger plug orv by a faulty connection in the scooter. Sometimes the charger socket is faulty, check for heat damage or melted plastic.
Check the battery connectors. Good luck. Neil.
Posted on May 29, 2010
lennieg2000
  • 692 Answers
SOURCE: Hello. I need a
Any 4 amp charger you can find will work to charge your batteries. Preferably find one that has an on/off switch on the charger. You should be able to find one on ebay a lot less than what the scooter repair store quoted you Check around your neighborhood someone might have a second charger that they are not using. Since Medicare will pay for a new chair every 5 years someone might have a extra charger laying around. Hope this helps you
Posted on Oct 18, 2010
tbreeze47
Tom Carson
  • 3083 Answers
SOURCE: Traveler Elite Plus: Unit will
I've been a tech for years, and sometimes any assumption that something is "good" can be the one thing that trips you up for awhile. This is a really tough problem, since you've done about all you can to solve it. Here's what I suspect...either the batteries don't have the same current capacity as the old ones, or they could be underengineered, or even defective. I've bought car batteries, on two occasions, that were bad, even though they swore they were good.
You'll have to get someone to test them for their load capacity, that's the only thing I can figure at this point. Not sure who will have this capability- you might call around to some service shops and see if they can help, or know someone who can.
If all the connections are good, and the motor is new, there just leaves the harness itself and the batteries to suspect.
Ensure the batteries are good, and then you will have to check the cables for load capability and integrity.
Good luck, and hope this helps.
Posted on Nov 24, 2010
jhajlambert
  • 140 Answers
SOURCE: 3-wheel go go scooter, on a full charged battery,
I would say that both the batteries are not holding a full charge ....I had one in the past for my mother and if it was not chraged on a regular basis the batteries would die out ....the cheapest and easiest route here is to try new batteries.
Posted on Mar 14, 2011
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Battery light comes on charge light will not dc out put 24v 4v charger prism GHC-244000il-EMI no output when could I have a problem other than charger has an 1605 inhibit boost
hi , what is the name of the mobility scooter please ? have you checked that there is no fuse fitted to the charger line ? can you please try another charger ?, this will eliminate the scooter ...
Regards
Rob
help me help you ...
Sep 21, 2015 | Health & Beauty
Need battery charger,model number is,2904-24l,where can i get reasonable
From Pride, MK batteries or your local mobility service centre.
Have you checked eBay for mobility scooter chargers. be careful on second hand chargers.
Mar 28, 2015 | Pride Legend XL Heavy-Duty 4 Wheel Scooter...
I need to find batteries and a charger.
hi, the batteries will not charge correctly if the charger is faulty ? now what is the scooter model ?
regards
Jan 12, 2013 | Health & Beauty
I need to find where I can get a battery charger for Model # PL3-01 Motorized scooter
Is it a sealed lead acid scooter battery? Youcan get the replacement battery as per your scooters model number at http://www.monsterscooterparts.com/scooter-trickle-battery-chargers.html.All that you have to do is just search with the model number and you will getthe battery charger. Hope thiswill help you. Good Luck.
Jul 11, 2011 | Pride Luxury Line Maxima Scooter - 4 Wheel...
Wont hold a charge. Batteries checked out ok. Could it be a short? Is this common?
If the batteries have been volt tested OK and they wont hold a charge, check your charger to make sure it is functioning properly. If there was a short, the scooter most likely would not work or would give a flashing light code. Batteries typically will not hold a charge when they are damaged, have been sitting unused for a while or if there is a mechanical issue that is causing dtrain on the motors. Check the air pressure, bearings and ensure there is no noise or vibration that may indicate a motor failure. If all those check OK, replace the batteries.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Hello. I need a battery charger for a Rascal 325. This is the second one. It is not an OEM but a Prism GHC-244000IL-EMI 24V Model AE244000. They tell me at my scooter repair store that the OEM costs...
Oct 18, 2010 | Electric Mobility Power Electric Scooter...
I replaced new battery but still the scooter runs slow
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
Oct 04, 2010 | Razor E300 Scooter
Scooter dash lights flash up and down .were normaly they come on and stay at top .they just constantly run up and down ..batteries show on charger in boot .that its fully charged
Hi. Some scooters will show a pattern like this while the charger is operating, but when the charger is turned off it should stop. Some internal chargers have a relay that is activated while the charger is on to disable the scooter. Does the scooter operate properly after the charger is turned off? If not, then unplug the charger where it connects to the batteries inside the scooter and see if this helps. If this helps, you might need a new charger.
Good luck. Neil.
May 14, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Health & Beauty Logo
397 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
