I need to know if I should buy HDMI to component cables or HDMI to DVI cables or HDMI to Component CONVERTER ???
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Testimonial: "Hi Steve, thanks for the information. However i still have a question: my xbox only has HDMI cable output. It is the latest model XBox360E, that looks more like the XBoxOne. Should a "HDMI to Component" cable work ?"
An HDMI to HD Component cable should still work between the Xbox360e to your TV. It will provide the superior "HD" video (that looks great on your TV) and standard stereo audio (which is the best your current TV supports). Some cables provide an Optical (TOSLink) output, which would be a Dolby Digital audio path to an optical jack (if present) on your home stereo. Of course, if your home stereo isn't a 5.1 or better system or lacks an Optical TOSLink input, it doesn't make sense to buy that cable if it costs more than the standard L + R audio output version. The Standard A/V cable will provide only "SD" quality video (which is sub-standard for your TV's picture) and standard L + R stereo audio (the best your current TV supports). See for more details: https://support.xbox.com/en-US/xbox-360/...
U need =HDMI to Vedio convertor
