Question about Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair
No green lights all others flashing inoperative
Posted by John Dodds on
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
What does this sound like to you?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Mar 25, 2016 | Emerson LC320EM9 32 in. LCD HDTV
MY HEADLIGHTS ARE BLINKING AND MY HORN IS TOO AND RELAYS ARE BLINKING TOO.
Search Results
    2002 saturn l200 headlights and dash lights blinking - Saturn ...
    www.saturnforum.com/.../saturn-l-series.../2002-saturn-l200-headlights-...
    Mar 6, 2013 - My wife told me that on occasion the headlights and the dash lights willblink when she lets off the. ... 2002 saturn l200 headlights and dash lights blinking.... 2000 LW2 dash lights Inop, spotts56, Saturn L Series Sedans & ...
    Saturn l-300 wagon has flickering lights - Car Forums at Edmunds.com
    forums.edmunds.com > Saturn > Saturn L300
    My wagon 2003 l-300 has flickering lights and when the radio is off you can hear the ...My Dad has a 2002 Saturn Lw series wagon. the transmition has been ...
    why a green light always keep flashing when running? - SaturnFans ...
    www.saturnfans.com > ... > Models > Saturn S-Series > S-Series General
    Apr 17, 2007 - 20 posts - ‎14 authors
    S-Series General. ... A green light alwyas keep flashing when my saturn 2002 sl2 .... I had a similar issue with the headlights of a 2002 Impala, but it was an .... I never noticed on my SL2, my L200 or on my Ion now if they come ... Flashing Dash Lights
    Oct 20, 2008
    Flickering lights?
    Nov 21, 2007
    L300 2004 - Lights Flickering - Have some help
    Nov 2, 2005
    Flickering Lights
    Feb 5, 2005
    More results from www.saturnfans.com
Feb 09, 2016 | 2002 Saturn L-Series
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Will not come on and front lights flashing red +
If your set is the KV-24FS120, then the standby light should blink with a repeated pattern. Count the blinks and post that number here. It is a diagnostic code that will indicate the defective circuit. Having that information will allow us to suggest repair options.
Thanks,
Dan
Apr 15, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Built in flash inoperative. Other functions still
Hi!
Yes, a well known problem for A200. The flash board has to be changed. You should contact Sony - I believe this a factory problem, so you should ask them to make it for at least half of the price. I work in a Sony service center and I have repaired a lot of these.
Tom
Aug 06, 2009 | Sony Alpha DSLR-A200K Digital Camera
Kyocera FS 1020D
You might be out of toner.
Jul 22, 2009 | Office Equipment & Supplies
1994 ford f-150 with day time running lights headlightnot working
Daytime Running Lamps
The daytime running lamp (DRL) system is designed to turn the high beam headlamps on, with a reduced light output, and without illuminating the high beam indicator lamp in the instrument panel. You have a DRL Module.
The multifunction switch is the stalk on your column.
This is 96 F150 circuit. Don't have 94.
Symptom Chart, Headlamps HEADLAMPS Condition Possible Source Action
  • Headlamps Inoperative
  • Circuitry open/shorted.
  • Damaged headlamp switch.
  • Blown fuse.
  • GO to Pinpoint Test A .
  • Headlamps On Continuously
  • GO to Pinpoint Test B .
  • High Beams or Low Beams Inoperative
  • Damaged multi-function switch.
  • GO to Pinpoint Test C .
  • One High Beam or One Low Beam Headlamp Inoperative
  • Damaged connector.
  • Headlamp bulb damaged.
  • GO to Pinpoint Test D .
  • Flash-to-Pass Inoperative
  • Blown fuse.
  • GO to Pinpoint Test E .
Feb 25, 2009 | 1994 Ford F150 Styleside Supercab
Pride Mobility Products Used Jazzy 1120/2000 Electric Wheelchair Logo
78 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Bird
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
