Hi this is screen burn mode, press the menu button on the remote to stop it you may have to retune tv back in, if this don't work, you will need to go into the service mode and turn the screen burn mode off,to do this press menu on the tv and menu on the remote, you should see another screen pop up, select screen burn mode to off if the first sequence don't work try ok on the tv and ok on the remote, thanks
There are two kinds of pioneer color codes: pre 1999
P o w e r
Memory (+12v Constant)
Orange
Ignition (+12v Switched)
Red
Ground (-)
Black
Illumination
Yellow
Phone Mute
Yellow/Black
Power Antenna
Blue
S p e a k e r s
Right Front (+)
Gray
Right Front (-)
Gray/Black
Left Front (+)
Green
Left Front (-)
Green/Black
Right Rear (+)
Gray/Red
Right Rear (-)
Black/Gray
Left Rear (+)
Green/Red
Left Rear (-)
Black/Green
and 2000 or newer
Memory / Constant 12V(+)
Yellow
Switch / AccessoryRedGroundBlack
Illumination
Orange/White
Antenna RemoteBlueAmp RemoteBlue/White
Left Front (+)
White
Left Front (-)
White/Black
Right Front (+)
Grey
Right Front (-)
Grey/Black
Left Rear (+)GreenLeft Rear (-)Green/BlackRight Rear (+)VioletRight Rear (-)Violet/Black
Battery light green to yellow
Accessory yellow/black red
ground black black
Illumination light blue.red orange/white
Power antenna amp=blue blue
LF + orange/light green white
LF - light blue/white white/black
RF + dark green/orange gray
RF - white/light green gray/black
LR + gray/light blue green
LR - tan/yellow green.black
RR + orange/red violet
RR - brown/pink violet/black
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
The picture board of your monitor has developed fault. That is why the screen is black.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity,
because the fault is not something you can fix in other not to complicate issues..
The repairer will help diagnose and replace the faulty picture board and your monitor is back and better.
