SOURCE: Amana SBS Water and Ice maker issues
The water solenoid on the back of the refrigerator at the bottom is becoming clogged. There is only a very small hole in the diaphram of the valve. I suspect you have very hard water, or at least a fair amount of sediment in the water.
This valve will most likely need to be replaced by a qualified technician.
They sometimes can be cleaned, but it doesn't always work.
SOURCE: Kenmore refrigerator
hi fperry74,
please look at the back bottom part of the refigerator , if you could see a small condenser fan there. it might not be running or running very slow. correct that problem then.
that is why your panel is very hot because a condenser line passes thru that panel and if the fan is not running, then the temperature gets very hot.
the efficiency of the fridge is also affected.
i hope i was able to solve your problem.
pls rate me.
tnx
drcool
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
SOURCE: ice maker will not dispense the ice
The auger motor and coupling in the rear may be frozen and won't turn.
Remove the ice bin.
Place a screwdriver or similar device in the forks of the auger and twist counterclockwise till it moves. The replace the ice bin and try again.
It will be difficult to move.
If that does not work. Turn off the fridge and use a hair dryer to hrat the auger gear and motor till it frees up.
