Hi Harrison
Letting the smoke out of any electrical device is never a good symptom. It sounds very much to me as if your transformer is checking out. A usual suspect is a short circuit of the tracks.
Sorry I couldn't have given you better news.
-Steve
Not everyone will agree with me on all of this, because many people are very cautious about electrical stuff, so do proceed with caution. But, I would start unplugging it. Then unscrew and open the top. You will probably need to remove the light bulbs under the green and red caps to get the top to lift off.
Lionel Toy Trains Service and Repair Information Library from OTTP...
Good Luck, Dave
SOURCE: I have a Lionel ZW transformer older version
Just wanted to add a note to this problem you are having....Question is this...How big is the train layout and how many power clips do you have on the track??
Reason is being if you only have one power clip for the whole track, you will notice a decrease (slowdown) of the train in certain area(s) so i would recommend adding another power clip or two to your layout, also If you are using old regular O track, make sure you have the metal pins in all 3 railsHope this helps
