Miscellaneous Logo
Judy Bradley Posted on Mar 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the difference between a gigabite and Megibite?
Lars Olsson
Level 3:
Brigadier General:
  • Master 3,400 Answers
  • Posted on Mar 26, 2015
Lars Olsson
Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048532
Points
10330
What is the difference  between  a gigabite and Me - 25606309-syhkzuyhiyydcwcvnmt01mlo-5-0.jpg HERE ARE THE MEUSSURMENTS.
ROD GANDY
Level 3:
  • Master 1,602 Answers
  • Posted on Mar 25, 2015
ROD GANDY
Master
Level 3:
Answers
1602
Questions
0
Helped
591479
Points
4916
Metric prefixes powers of 10
1 megabyte = 1000000
1 gigabyte = 1000000000
1 terabyte = 1000000000000
8 bits to 1 byte
6
1 megabyte = 10
9
1 gigabyte = 10
12
1 terabyte = 10
depending on what bit conversion you have, 16bit, 32bit, 64bit, 128bit
be equal to 2bytes
If I used .129 gigabites of 2 gigabite plan, how much do I have left?
Ah. Now, I can answer.
You have 1.871 gigs left, or 1871 megs left. You've used about 7 percent of your space.
Need drivers for Gigabit Ethernet with POV, DDR1
please go to manufacturer website and download driver
One of the LED is orange instead of green
I also have the DGS-1008D 8-port switch and it connects fine at gigabit speeds between my 5 PC's - I would check the cabling again, as mine was plug and play. As soon as it was hooked up and switched on, I got the green light for the gigabit connection - my 100mb router (also D-Link) connects with an orange light, as it cannot achieve gigabit speed.
Hi there and thanx for the reply.
I have connected PC's with the gigabit cards to the point where the one machine connects at 1Gig. All machines connect at 1 Gig at that specific point. So it is either the cables itself or the connection in the jack itself problem
2answers
What Ethernet card should I buy for Dimension 4300?
Depending on the speed of your internet connection you could get either a fast ethernet card or a gigabit card. I would recommend the latter since that is the direction technology is moving. The brand shouldn't make too big of a difference, I'd go with a card that had fairly good reviews. You can look for one on Amazon or NewEgg. Hope that helps.
Teaming Intel Card
That NIC is end of life ...obsolete
Ethernet card
Hello my friend thats ok.
Is just that the site i gave you, you can easily find what you are looking for from different maker and model of cards from different mnufacturer but if you cant go to this site of Dell ethernet card ok
You can use any ethernet card just depending on the slot it will go into ok
now take this site :
www.accessories.us.dell.com or
www.startech.com/category/parts/networking/network-cards/gigabit-adapters/list.aspx
MSRP st1000bt32.athumb.jpg 10/100/1000 Mbps 32 bit PCI Gigabit Ethernet Card
ID#: ST1000BT32 $29.99
ec1000bt.athumb.jpg Gigabit ExpressCard (10/100/1000 Mbps) Network Card
ID#: EC1000BT $55.99
st1000btpex.athumb.jpg PCI Express 10/100/1000Mbps Gigabit Ethernet Card
ID#: ST1000BTPEX $69.99
cb1000bt.athumb.jpg Gigabit CardBus Network Card (10/100/1000 Mbits/sec.)
ID#: CB1000BT $64.99
RATE THIS SOLUTION
ok
WS-GS5486
If you have device A connected to device B over a Gigabit link, and the link does not come up, perform this procedure.
Step-by-Step Procedure
1. Verify device A and B use the same GBIC, short wavelength (SX), long wavelength (LX), long haul (LH), extended wavelength (ZX), or copper UTP (TX). Both devices must use the same type of GBIC to establish link. An SX GBIC needs to connect with an SX GBIC. An SX GBIC does not link with an LX GBIC.
2. Verify distance and cable used per GBIC as defined by Cisco.
3. If either device has multiple Gigabit ports, connect the ports to each other. This tests each device and verifies that the Gigabit interface functions correctly. For example, you have a switch that has two Gigabit ports. Wire Gigabit port one to Gigabit port two. Does the link come up? If so, the port is good. STP blocks on the port and prevents any loops (port one receive (RX) goes to port two transmit (TX), and port one TX goes to port two RX).
4. If single connection or Step 3 fails with SC connectors, loop the port back to itself (port one RX goes to port one TX). Does the port come up? If not, contact the Cisco TAC, as this can be a faulty port.
5. If steps 3 and 4 are successful, but a connection between device A and B cannot be established, loop ports with the cable that adjoins the two devices. Verify that there is not a faulty cable.
6. Verify that each device supports 802.3z specification for Gigabit auto-negotiation. Gigabit Ethernet has an auto-negotiation procedure that is more extensive than the one used for 10/100 Ethernet (Gigabit auto-negotiation spec: IEEE Std 802.3z-1998). When you enable link negotiation, the system auto-negotiates flow control, duplex mode, and remote fault information. You must either enable or disable link negotiation on both ends of the link. Both ends of the link must be set to the same value or the link cannot connect. Problems have been seen when you connect to devices manufactured before the IEEE 802.3z standard was ratified. If either device does not support Gigabit auto-negotiation, disable the Gigabit auto-negotiation, and it forces the link up.warning.gif Warning: Disabling auto-negotiation hides link drops or physical layer problems. Disabling auto-negotiation is only required if end-devices such as older Gigabit NICs are used which cannot support IEEE 802.3z. Do not disable auto-negotiation between switches unless absolutely required to do so, as physical layer problems can go undetected, which results in STP loops. The alternative is to contact the vendor for software/hardware upgrade for IEEE 802.3z Gigabit auto-negotiation support
Top Miscellaneous Experts
ricebike
NOEL
NOEL
JohnSal
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
