Try this site, very old machine, Minolta no longer has it on its web site. Service manuals electronic components datasheets and equipment schematics...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: MINOLTA MD-1 MOTOR DRIVE MANUAL
Join
http://tech.groups.yahoo.com/group/ManualMinolta/
Look under "files". I found it easily with no problem. pdf file 828K but I can't upload to you.
SOURCE: service manual for KONICA MINOLTA Bizhub 210/162
Swithc off the machine Press stop button and hold switch on the machine. problem will go.
Good Luck
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: minolta c203 service menu
They extended the life of the image unit. They did not reduce the amount color in the print. Once they extended the life, the image unit will go until its copy qualilty will become completly destroyed. You will have to replace the image unit, sooner or later.
