Sir, the toner bottle motor assy. needs to be replaced. will take quite a bit of work to get to, recommended a service tech qualified on Biz hub 350. This series is well known for the toner bottle assy. fault as is the di3510 series prior to the Bizhub 200/300 series.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: di3510 new developer new drum
Hello and Welcome to FixYa!
Sir actually according to the specification of Minolta Di3510 printer the "Halftone Reproduction" is 256 gradations, warm up time is 17 seconds and maximum "Memory" is 40 GB maximum which support 2000 copies of printing at one time, So when you print 2000 copies its memory becomes full and automatically the light of the printer goes.
Its simple solution is that after the consecutive 2000 copies when the light goes off, simply Turn Off the printer wait some time to reset it, After some time when the memory will become empty, it will be again able to print and if it start to show you message to add tones then simply change the toner and it will become again to print.
Here is Specification Document of Minolta Di3510 printer, You can see its specifications from here and you will also see the about its maximum range of 2000 pages in memory section.
I hope you have clear picture in your mind and this solution surely helps you.
Don't hesitate to let me know if you have some confusion
Thank you for using FixYa!
