Question about Weiser Lock Powerbolt 1000 Lock
I am house sitting and I put in the code and the door won't open I tried a couple of times and then there was a long beep? What can I do?
My craftsman garage door opener is beeping (2 hours). How can I stop it
Our garage door opener has a safety beam across the floor which prevents the door from closing on objects which are sitting there. This safety feature also makes an annoying beeping sound each time the beam is crossed. This tutorial will show you how to disable the beep, but still keep beam functional. https://www.youtube.com/watch?v=Cn_vGe_7_x4
How to change code N15115
Input the new code (1-8 digits then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again Emergency Key - store in secure place NOT inside the safe. To ensure the batteries have been installed correctly test before closing the door. 2 bolt locking mechanism, opens with a digital code or emergency key. Floor or wall mountable, immediately locks out after 3 invalid code attempts. Durable steel construction, model Name 24/7 Digital Safe, material, galvanised steel. Opening the safe a. Pre-set factory code 159 b. Input 159 (the yellow light will flash and the buzzer will beep then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened Closing the safe: close the door, input the code (the green light.
Oven door won't close all the way
I have had that trouble a couple of times. This might work. The door is usually attached to the body by two hinges with arms. You can lift the door off those arms and hinges by opening the door a few inches and lifting the whole door up in the air. Try this GENTLY. If the door acts like it will come off the body, it might be misaligned. Try lifting the door, and putting it back a few times, sort of gently twisting it from side to side. Really be gentle. This has worked for me several times. Be blessed.
May 12, 2013 • Ovens
1helpful
2001 Rodeo 2.8 Turbo Diesel running perfectly one day won't run the next. Seems to be after it sits for a couple of days. Any suggestions?
Hi Peter, If the vehicle turns on the starter all the time, and sometimes starts and other times fails, check the fuel filter for leakage. Sometimes air gets into the fuel system. When it gives problems, open the bonnet (hood) and have someone pump the pump on top of the filter housing. If it feels soft when beginning to pump, I would suspect either a leakage on the fuel line or the filter housing. If you need to replace the housing and filter, remember to fill the replacement filter with clean diesel fuel first. the glow plugs can also cause problems if one or more have burned out. Regards John
2answers
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
I put my kenmore oven on to clean.I PRESS CLEAN AND THAN START.THE DOOR LOCKED AND THE CLEAN LIGHT CAME ON.AFEW SECOND LATER I HEARD BEEP BEEP AND ERR-F9.GOT MY BOOK OUT AND FOUND NO ANSWER.SO I CALL...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
2answers
Wired alarm beeps every 30 secs. No reset code or panel box.
You may need a code to silence it, but you can try pressing the '*' key on the keypad.
If it is only beeping when you exit or enter through a protected door, you can remove the magnet (likely drilled down into the top of your door(s)).
If it is a low battery, you'll need to power down the system. To do that you will have to access the main control panel, pull either lead from the battery and disconnect the transformer in the house. If you have difficulty locating the transformer, go to your circuit breaker panel and shut down your circuits, one at a time, until your keypad's display is blank--track the circuit to locate the transformer.
Kenmore Electric Range Slide in....beeping while not in use
Hard wiring is O.K. and really better because you don't have to fool with the plug and the loss of or poor connection there. You can just turn the power off at the breaker. Without knowing what the F9 error code is, you may have a problem with the board inside the control panel. To get the door open, try to push and hold door closed at the same time. This may loosen the tension on the closer and allow it to open. Pull the lever to open it. If not, try to moderately tap on the door where it latches and it may open then. Next, slide a thin screwdriver into the latch and free it up there. Once the door opens, I believe your oven will work. The oven believes it is in the self clean mode. When you get the door open, turn on the oven with the door open and it should heat. If it does not, check the wiring in the back and you may find that one of the wires has burned off the control switch for the oven. I know this sounds like a lot, but it should save you a tech call and a couple of hundred dollars. Hope this helps.
157helpful
3answers
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
5helpful
6answers
3 beeps
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
Weiser Lock Powerbolt 1000 Lock Logo
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
