Question about Tomtom Sat Navigation Car GPS Receiver
How do i update my tom tom one
E13-023289 ni14644
Posted by ALAN BURGESS on
LP
  • Tomtom Master
  • 514 Answers
When you connect your TomTom to your computer (USB port) ... you can use the TomTom HOME software to check the updates available for your GPS.
This assumes you've (previously) registered your GPS on the TomTom website, and you have TomTom HOME installed on your computer.
If not, register your TomTom on the TomTom website (identify it with your email address), and install the TomTom HOME software on your computer.
Then when you connect your GPS device to your computer, the TomTom HOME software should start up (or you can start it up), and you can log into your TomTom account ... and the HOME software will automatically search and let you know if / what updates are available for your GPS.
Posted on May 06, 2015
How can I update the latest free maps
How to Update Free Maps on GPS TomTom via Review
How to Update Free Maps on GPS TomTom via Review TOMTOM VIA CUSTOMER TECHNICAL SUPPORT PHONE LINE 1-866-486-6866 TOM TOM VIA "TOMTOM VIA" "TOM TOM UPDATES" "HOW TO UPDATE GPS"
Mar 16, 2016 | Tomtom ONE GPS Receiver
Factory reset gps
UNFREEZE Tom tom sat nav USING WINDOWS OR MAC PC
This will unfreeze your tom tom after exhausting every avenue this works!
You will need Internet access.
Ensure you have the correct tom tom desktop softwear installed on your computer for your tom tom device.
If not then download from tomtom
Removed sim card from tom tom located under sticker lower end of tom tom.
Carried out on a windows laptop with windows 7
(Note this should also work on mac although I did not get to try it and it is stated you will need rosetta on intel macs)
Ensure you download the flash tool for tomtom (clear_flash.dmg) for your operating system windows or for the mac VERY IMPORTANT YOU HAVE THE TOOL DOWNLOADED FIRST.
1.For windows: www.tomtom.com/updates/clear_flash/clear_flash.exe
connect tom tom to computer
find the tom tom on your computer and select all the files
you can firstly copy these to another location or separate drive before deleting all files.
Now delete ALL the tom tom files
Format your tom tom to FAT32 if using windows (im not sure of the mac settings yet)
Keep your tom tom connected to your computer
Run the flash tool and Flash the tom tom memory with the tool.
Restart your tom tom
It will update (but this time it should work!)
Select done after update
Tomtom reboots (restarts)
It may ask you to install a new update but there may not be any update to install just
Select yes to update.
Eject tom tom from your pc by selectinglower right corner symbol.
Now unplug device if ejected correctly
Congratulations your device should now work again.
Note I did not replace my sim card as it is not required to work the gps.
Hope this helped someone.
My device does not keep its settings What should do
Aug 14, 2014 | Tomtom TOM TOM ONE WE V3 GPS Receiver
Update tom tom go 720 for free
You may be able to get "free" map updates from (illegal) underground sources. But that's not recommended.
Yes, you're right, you can simply get a new TomTom GPS and get the latest map(s) for it. Consider getting a TomTom with lifetime maps ....and you won't have to pay for any map updates.
Sep 17, 2012 | Tomtom GO 720 GPS Receiver
I want update my tom tom how could i update
Click here to visit the Tom Tom update page. They allow 1 free map update and afterwards it is paid. You get the map and software from that link. You connect your Tom Tom to your computer in order to update it.
Aug 22, 2011 | Tomtom One XL GPS Receiver
HOW DO I UPDATE MY TOM TOM GPS N14644?
Need to update my tom tom. I have no idea how to do it.
Jun 24, 2010 | Tomtom ONE XL GPS
Tom Tom One slow to configure with satellite
your tom tom needs to be updated,go to tom tom home on the computer and connect your tom tom to the computer and you can download updates there, you can get free updates, hope this helps.
Sep 29, 2009 | Tomtom ONE GPS Receiver
After having my tom tom for 10 months I finally downloaded the Tom Tom Home and updated my Tom Tom. However, after doing so, I disconnected my Tom Tom and it no longer works. I only have the Tom Tom front...
Probaly you're still within the gaurantee periode, go back to the store and don't tell them that it is you're own fault that you've bricked your tom tom, they only need to know that it stopped to work without anny reason, that this happend with normal use, they should replace it for you or send it back to tom tom to fix it for free.
Next thime don't unplug you're tom tom when it is updating, be patient,
the software tells you when it is finished updating.
Succes.
Sep 28, 2009 | Tomtom ONE GPS Receiver
Brand new Tom Tom One 125 showing blinking red X when turned on
I was able to speak with Tech Support at Tom Tom and got sent some links for solutions to these problems.  I was able to solve the problem following directions from this website.  Without that response of the support person to this specific problem, I would still be without my new GPS system.  Turned out that there is a conflict with the MAC OS and updates to Tom Tom, but there is a solution to this that worked for me.
If you get the continual red circle with blinking "X" and recently tried updating either your maps or most recent app, here are the two web links that will solve the problem:
www.tomtom.com/10324 (to disable SPOTLIGHT from causing a conflict on the Tom Tom ONE)
www.tomtom.com/9091 (general info for removing software and re-installing software to the Tom Tom ONE)
Do the disabling of SPOTLIGHT first, then remove and re-load software for Tom Tom ONE.  Good Luck.  This did the trick for me.
Jan 25, 2009 | Tomtom ONE GPS Receiver
Tom tom GPS Map Updates
you go to tomtom.com and make sure you have website open before you connect your tomtom to the computer.
May 22, 2008 | Tomtom GO 910 GPS Receiver
Tomtom Sat Navigation Car GPS Receiver Logo
220 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
