Question about Asko Washing Machines
My Asko Asea 4kg 12002 front loader washing machine is now washing clockwise only whereas it used to wash clockwise and anticlockwise. I have had this machine for 20 plus years and have always been very happy with it. Any suggestion as to what is wrong with it now? Everything else is working and the machine is in A1 condition. Would love to be able to fix it. Thanks Liz
Posted by Elizabeth Nakhuda on
Catherine Duquesne
Hello sir madam, I put a detergent on the way this morning in my ASKO 12002 washing machine but IT just got stuck at n ° 4 of its program then did not rinse at n ° 5; then, it did not wring out either at n ° 7, or anything and arrived at 8 ... it therefore goes through the different numbers but without any action ... to remain filled with water in the tank! What should I do, please? I really appreciate my machine which I have had for a long time and would love to have it repaired. Thank you in advance for your information and various tips. And see you soon, I hope. Cordially, Catherine D. BELGIUM
Posted on Jan 12, 2022
Simpson swt8043 top loader washing machine agitates anticlockwise only from new.
The agitator is designed to “ratchet” and turn one way but not the other. If your clothes are being twisted, that is most likely a transmission problem where it tries to agitate and spin at same time
Why does water overflow from the sopa dispenser of my asko asea 12002
Is it foamy, if it is then your using top loader detergent.
How do you replace the pump cover with attached needle trap? On ASKO front loader washing machine W6231?
it usually unscrews anticlockwise, but check to make sure there isnt a retaining screw that needs removing first. they can be a bit on the tight side
I don't have a manual for asko asea 12002 front loading washing machine and cannot find one on line.
I have tried my own FixYa advice which I offer to all and with similar success!!!
I would email mailto:[email protected] and ask them. Sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
My washing dries coarse since I purchasing my Asko front loader. Towels and socks in particular. What can I do to stop this from happening?
Use a washing softner in the final rinse water such as Downey Apparently you have hard water that lealeaves precipitated minerals in your clothes.
1helpful
Hi - I have the Askko asea 12002 and the machine won't empty water and therefore door won't open. How do I get around this. I need to get the clothes out ASAP.
Remove outlet hose at back of machine and drain into a bowel or bucket the door will then open. Check your filter is not blocked and also the pump
2helpful
2answers
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
2answers
Asko front load washing machine
When u use front loaders you normally don't need a soak. And i don't think you need bleach. Use front loading powders for the machine. The automatic machine is supposed to work for you. The water empties out, so you can open the door.
Rate me pl if helped..............
No instructions
Click on Asko (or washing machines) (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And rate me if it works.
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
