Hi, without being used, the mashine fills up with water and now even I have turned of the water to the mashine. I can use the pump to get it away, but keeps on coming back
Check the program dial or settings. Put the machine off. then the water slot should close. If it does not close it is defect and you should ask a tech to replace it, or buy a new machine.
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine.
Thankfor using fixya.
If your washing machine will not fill, only hot or cold will fill or is slow to
fill then read these tips. I have covered many of the things that can happen in
these tips…
You do not need airflow for the washing machine only the dryer. And yes you can put it inside of a cupboard or cabinetry,as long as you have water supply, and waste water discharge access
