Use one of the Samsung codes. Code that worked for my 60inch Vizio was 0030. Good luck!
This remote control have no set-up codes to Vizio. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
SOURCE: radio shack 3 in 1 remote 15-2147
Here is the user guide:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502147_PM_EN.pdf
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
SOURCE: NEED REMOTE CODES FOR RADIO SHACK ALL IN ONE REMOTE
Looks like:
0093, 1250, 0150, 0178, 0868,
0836, 1917, 0019
Check manual here:
http://tinyurl.com/5zvjfl
SOURCE: Radio Shack 3 in 1 remote code...
i need the codes for a radio shack 3in1 remote #15-2147 also the codes for an orion tv
SOURCE: Need codes to use radio shack hdtv remote 15-135
can not program my control can send me a tutorial or what's in store radio shack
