I have a tv esa model # ET432E. I have tried channels 02-09. I have also tried 91 and 92 which worked for older tv's in the past. I am not sure what else to try.
Usually the tv will switch automatically to the correct reception mode as soon as it detects an input into the scart socket.
I have and have had a number of tv sets and they all do this, though I do remember many years ago needing to select the AV channel. I believe these days the AV channel is for the other audio/video input sockets.
I suggest you connect your dvd player to the tv, switch on the tv and then press "play" on the dvd.
You should be able to enjoy viewing without further effort.
If you change channel on the tv to check what is on, the dvd reception will be lost. To save the trouble of disconnecting the scart lead and reconnecting I use a manual scart distribution box so simply pressing the button provides the required interruption so dvd viewing can be resumed.
