i you want use it for taking picture, u need webcam software come with your laptop like cyberlink webcam to make it functioning, but if u want to use it for cam chat, you just need ym or skype to make it functioning but make sure you webcam driver is installed befor you can use your webcam.
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
working OK ?
CONFIGURE TO SKYPE Connect webcam Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly. The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted. Mine, I just unplug it from the USB and plug it back in to reboot the software. If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype. On the 'Tools' menu, click 'Options'. In the navigation pane of the Skype 'Options' window, click 'Audio Settings' Run down the list setting your defaults Select your webcam as the default microphone. Make a free test call Click 'Save' In the navigation pane of the Skype Options window, click Video Settings. This will launch your webcam Adjust quality of picture in 'Settings' Check the correct webcam is shown as default Click Save Test your webcam by making a Skype test call. For more information about how to configure Skype Messenger, please visit the following Skype Web site: http://support.skype.com (http://support.skype.com)
Skype ? Before you can use your webcam in any chat program you have to configure it to that program
working OK ?
Sounds like your software is looking at a video card and not your webcam. Run through the setup again
working OK ?
Launch the logitech webcam toolbar - start the webcam by clicking on the 'Quick Capture' menu ( 2 film frames ) With webcam running click on the 'Settings' menu ( 2 gear wheels) Check if the webcam has a focus ring around the lens that you can rotate to sharpen the picture. Play with the controls to achieve the best image possible Close the Logitech toolbar.
working OK ?
Normally you can do video call. While chatting and enable the video is possible with the latest version of skype 4.1.0.179
Another options also is to use is use a other software for video like msn or yahoo messenger.
First I would recommend you to download the latest version of skype Follow the link :(www.skype.com/download/) While configuring be sure to use the following setting: 1.Start skype. 2.In the navigation pane of the Skype Options window, click Video Settings. 3.Adjust quality of picture in 'Settings 4.Check the correct webcam is shown as default Click Save Test your webcam by making a Skype test call. If you need further help you can log onto: (http://support.skype.com) ok
connect the webcam in to the usb port and install the driver for the webcam use the driver provide by the company..... and open the webcam software ....
Hello my friend, to access webcam and used it 1. Plug your webcam into your computer. 2. Insert the CD installer driver of your webcam then run the setup.exe to install its driver. 3. After you install try to run the webcam to used. 4. You can used the webcam for spying purpose, surveillance, security and even YM and SKYPE you can used it to have a cam while you are chatting in your YM and talking using your SKYPE.
Sorry, just noticed your message today at 2045 hours 17July08 Korea time. If you haven't already fixed this issue, please let me know what brand and model of webcam you are speaking of in relationship to WinXP and what service pack you are using?
