Kenmore Elite Oasis 27052 Top Load Washer Logo
E
Eric Pavlik Posted on Mar 23, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to locate a tub seal, number on seal is 8545956. I don't need the whole kit, just the seal. Is it possible to get just that? If so could I be guided to where I could get it?
  • Richard Roth
    Richard Roth Apr 06, 2015
    Here is a link to all the parts for that model. http://bit.ly/1GDNPOV
Richard Roth
Level 3:
Top Expert:
  • Kenmore Master 9,472 Answers
  • Posted on Apr 01, 2015
Richard Roth
Kenmore Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2626584
Points
28464
What is the model number listed on the unit?
Testimonial: "model number is "110.27092603""
ka4iup
Level 3:
  • Kenmore Master 4,062 Answers
  • Posted on Mar 23, 2015
ka4iup
Kenmore Master
Level 3:
Answers
4062
Questions
0
Helped
1095346
Points
51404
Recommend using the Sears part search website. You can order parts through Sears repair facilities.
http://www.searspartsdirect.com/
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Leaks from underneath
see this causes and fix it. God bless you
Drain Pump If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Tub Seal and Bearing Kit If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal kit can be replaced. This is common and relatively easy to replace.
Tub Spin Seal If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. This is common and relatively easy to replace.
Tub to Pump Hose If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Spin cycle makes jet airplane takeoff noise. assume main bearing on spining tub is out. What part replaces this bearing? Diagrams do not mention bearing!
Bearings do exist but need a special puller to remove. If techs i n your area have it part numbers are 22002934 , 22003441 also needed is spacer 22002935 and seal kit 12002022 or else you need to order the whole outer basket
Maytag Dependable LAT8824AAE. Main tub seal leaks
The part number for the mounting stem and seal kit is 6-2095720 it cost about 85 bucks retail. You will also need to buy a special maytag spanner wrench to remove the inner tub. Its NOT an easy job the inner and outer tubs and hoses all need to be removed. The seal kit comes with no instructions. If you had a service company do the job it would be probably around 250 maybe more. We charge 104.95 labor for the job. Good luck _MJ_
2helpful
3answers
Looking for replacement bearings for the outer tub to inner tub on our Maytag FAV6800AWW, S/N 13389034ET. Don't want to replace the whole outer tub assy.
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
MAH4000AWW Bearing Noise When Spinning
12002022 is a seal kit only. The outer tub replacement is the correct fix, The part number for your unit is 22002907 and crosses over to 22004465. BTW. the replacement tub includes the seal kit and for the price I usually change the spinner assy at the same time..There are two part numbers for that.. It depends on your washer series which is determined by the first 2 numbers of your serial number... Hope this helps... Bill
Leaking/ loud
Well the tub seal actually has the bearings inside of it. You can purchase one as a seal kit. However, replacing one requires specialty tools. I do not have the part numbers, but I do have a solution. Go to a local appliance parts store with your model and serial number (these should be located on the top rear side of the console) Tell them you need a seal kit for that model / serial number. When they bring it up, there are step by step instructions of how to replace your bearing seal inside the parts box. On the instruction sheet on the first page, it tells you what tools you'll need to do the job including the specialty tools and thier manufactures parts numbers so you can purchase them there or have them ordered.
Maytag MAV7200 Washer......needs seal and bearing kit
I HAD TO REPLACE THE SPIN BEARING ON MY MAYTAG ATLANTIS WASHER MAV9750,
it was making a loud noise during sin cycle, like a bad bearing would
make, jet engine kind of noise, i did replace the bearing and made a web
site with pictures on how to do it, since it almost takes all the parts
out, it will show you how to get to most of the parts in the machine, and
i also included links for downloading the repair manual, and parts at
appliance parts pros web site
http://maytagwasherrepair.googlepages.com/index.html
Alexander
vince
