Question about ZEEPAD 7 inch Android 2.2 Tablet
Why is the screen using 62% of the battery - ZEEPAD 7 inch Android 2.2 Tablet
Posted by Margarita Montes on
Harrie
    Top Expert:
  • ZEEPAD Master
  • 6,740 Answers
Because it is the most important interface. When you leave the screen off, you also could leave the whole thing off. They still can't make cheap displays that does not use lots of power.
Posted on Mar 23, 2015
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
Nextbook8 on charger 8 hours. An only 60% charged this time?
Good evening
This happened to my iPad. When I discovered that there were many programs open, I closed them and it charged.
hope this works for you as it did for me. Some one told me that it was a good idea to plug the tablet to a computer and charge it that way.
kolbrun
Feb 08, 2015 | Nextbook Premium 8 Se Android
Why has my acer a3 screen gone blank ?
The program of your unit is wiped out. reprogramming is the solution.
Jul 27, 2014 | Acer Iconia A3 10.1 Tablet - 16GB
How do I make my kindle fire screen brighter?
Adjusting Screen Brightness The screen on the Kindle Fire uses more power than anything else, and the brighter the screen, the more battery power it uses. To increase battery life, you can lower the brightness of the display.
Unlock the rest of this book. Swipe the status bar down to open the Settings drawer.
Unlock the rest of this book. Tap Brightness.
Unlock the rest of this book. Slide the brightness control to the right to increase brightness and to the left to decrease brightness.
Jun 21, 2014 | Tablets & eReaders
Why is the WiFi in my rca tablet killing my battery to fast
Wifi always drains battery life to some extent or another.. Best solution is to turn off wifi when not in use or needed, and or keep your device plugged in during extensive use.. try to figure out your battery life while using wifi, and also kill/turn off any unnecessary background apps like gps, etc.. you can also extend your battery life by keeping your back light and lock screens to turn down and set to automatically turn off after a min or so of non use.. hope this helps..
May 04, 2014 | Tablets & eReaders
Just purchased Ematic EDAN XL. I let battery partially charge and continue to have connected to wall electrical outlet. The touchscreen is not responding. I have reset it and it continues to sit until it...
Try cleaning the touch-screen with a tissue or touch-screen cleaning paper, then wash your hands and use a skin moisturizer on your fingertips. If it still doesn't work, something's wrong with the unit. The touch-screen should work down to the discharge limit of the battery.
Note: when you buy a new lithium battery or device that uses one, it is a good idea to charge it completely before using. Some types of battery charge controllers use this first cycle to calibrate battery parameters so you get optimum performance from the battery.
Nov 11, 2017 | Ematic EDAN XL 9 inch Tablet with 8GB...
Screen problem with Asus TF300 10" tablet
Did you put a new battery in it or did you buy it used? Because it doesn't like the battery.
Aug 18, 2012 | Tablets & eReaders
How to fix not working touchscreen? Do i have to replace it?
The Samsung Q1 is a hybrid, ultra-mobile, touch-screen device that is basically a very small tablet PC. It features a 7-inch screen, weighs a mere 1.7 lbs., features a Windows operating system, doesn't have a built-in keyboard, and comes in a variety of configurations. The Samsung Q1 doesn't offer outstanding battery life, but you can make some moves to boost your computing time.
Dim the Screen
Dim the screen brightness. Four programmable application-launch buttons occupy the right edge of the Q1. One of these, the menu button, calls up frequently-used controls, including screen brightness. Reduce the screen brightness as much as you can, as it's one of the best ways to extend battery life.
Close Power-hogging Apps
Close applications and browser windows when you're done with them. Too many open programs drain the battery. Beware power-hogging apps. Watching a video or listening to music on your Q1 drains your battery life much faster than just using Microsoft Word or checking email. Turn off the Wi-fi networking when not in use. The built-in Wi-fi searches for a network when you're not connected, which drains battery life.
Properly Caring for and Feeding a Battery
Unplug the Samsung Q1 after the battery is fully charged. Leaving your Q1 plugged in 24/7 leads to some discharge from the battery. Consider buying a bigger battery. A 3-cell battery comes with most configurations of the Q1, but you can also buy a 6-cell battery to double the battery life.
Room Temperature is Best
Don't expose the Q1 to harsh conditions. Keeping the device in a blazing hot car in direct sunlight harms your battery life. If you use your Q1 in conditions above 95 degrees Fahrenheit, you can permanently damage the battery. Cold conditions don't harm the battery in the same way, but if you leave the Q1 in the cold, let it warm to room temperature before you use it.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Samsung Q1 Tablet PC
I need to know how to use the less and greater than button in my lenovo T400 keypad
Try to use the ALT command by pressing the ALT key on the keyboard, (hold and dont let go) then followed by:
60 for less than ().
Please let me know if you find this help useful. Thank you for using FixYa.
Regards,
Virtualhost
Oct 11, 2010 | Lenovo Tablets & eReaders
ZEEPAD 7 inch Android 2.2 Tablet Logo
51 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
