Question about Canon imageRUNNER 2016 All-In-One Laser Printer
Error cod e000007
Error code e000007 has appear then it dose not print or copy now?
Posted by Ephrem Lisanework on
Milan Hrncic
    Champion:
  • Canon Expert
  • 234 Answers
REPLACE THE FIXING FILM
Posted on Jul 19, 2015
2 Related Answers
kanwarjeet
  • 7 Answers
SOURCE: Error code E000007 - 0000 always appear on my Canon ImageRunner 3235 during copying and printing
The fuser film is not rotating properly.Replace it .
Posted on Jan 11, 2013
hrncicmilan
Milan Hrncic
  • 234 Answers
SOURCE: I have a copy machine canon 2420 I have error code E000007-0000
Check the connector of the fixing film sensor,replace it if necessary,or replace fixing film or DC controller
Posted on Feb 08, 2015
Solution for error code E000007-0000
that error means there is a problem with the fixing film. maybe is damaged or dirty
Nov 27, 2015 | Canon imageRUNNER 3300 All-In-One Laser...
Solution to erro e000007 on ir 2420 copier
What is remedy error code E000007-0000 for canon ... - Fixya
www.fixya.com/.../t14373194-remedy_error_code_e000007_0000_can...
Oct 12, 2007 - ... is remedy error code E000007-0000 for canon imageRUNNER2422/2420 ... Copier canon ir 5065 prolems with eror code e 000808-0002.
Imagerunner 2200 error E000007-0000 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Mar 15, 2007 - 4 posts - ‎4 authors canon ir 2200. hi, this machine do not have fixing roller. machine have fixing film assembly. this code is for damaged fixing film, on the end you ... Error Code Canon 3025 E000007-0000
Jan 30, 2013
Error Code The dreaded e000007-0001 error code!
Sep 5, 2011
Error Code Color ImageRUNNER 4060i has code ...
Jun 30, 2011
More results from www.copytechnet.com
Nov 05, 2015 | Office Equipment & Supplies
Feb 08, 2015 | Canon Office Equipment & Supplies
Error code e000007 0000
this looks good
...to code error E000007-0000 http://www.copytechnet.com/forums/canon/2954-imagerunner-2200-error-e000007-0000-a.html canon 3320irE000007-0000 how to solve my problem error e000007-0000 error
Jun 17, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
Reset error codes for Canon imageRUNNER 3300i
We followed the instructions from your tech. on which buttons to press to get into the menu function and then followed the directions for clearing the error code. After that turned the printer off and back on and the error code reset and the printer worked like a champ.
Jul 02, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
E000007-0000
Hello Evank,
I will gladly help you understand what's going on, but I am afraid nothing short of service call will actually resolve your problem. First off, the error code you are getting will cause the copier to just suddenly STOP...... which indeed will cause you to wind up with a paper stoppage but not a true paper jam. I apologize for what is like a distinction without a difference,but i just wanted to give the benefit of as much information as possible.The error code you are getting refers a subsystem of the copier called the fuser, which is a high temperature high pressure area that is common to all copiers. Because of the potential danger of high temp and pressure, all copier manufacturers design their products to be VERY sensitive to monitoring all aspects of the fuser as they do not wish to burn your building down. (bad 4 marketing) The E000007 error code refers to the fusing system. The code basically means that the on board computer of the copier did not get the signal it requires telling it that the fuser was working properly. That in fact it was not turning at the same time /speed as the copier. There is a sensor on this "fusing unit" that detects this speed. Either the sensor is bad, the fusing unit is indeed not turning at the correct speed and therefore is defective, or the dc controller ( a circuit board on the machine that processes most inputs) is defective. Most likely its the fuser/fusing unit which indeed is a "unit" and if it needs to be replaced will include the sensor previously described. The fuser (Canon also refers to it as a fixing unit) is good for @150000 copies more or less according to Canon and that is one of those things that I would call "according to the manufacturer" promises.In short, after this long winded description, unless you are a well trained copier tech, you will need one. But at least I have given you enuff info that you won't get screwed by the "copier dude" . :-) Of course I "IS" one. LOL . Good luck and I hope this helps you at least a little. ...........SPINAL........
Apr 23, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2016 All-In-One Laser Printer Logo
64 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
