Question about KLH DVZ-2500 System
How do I turn off parental control on a DVD player?
Posted by Andreana Blaney on
Scott P
  • 1,087 Answers
Go back into the set up and factory set it then go back through the end user set up again. Sony bipass code is 7774 for parental control Not sure where that 1s made. That dont work track down the customer service number for the manufacture
Posted on Mar 23, 2015
How do I reset the parental control password on a govideo dvd player?
Parental Control
Blocks playback of rated DVDs based on
their content. Not all discs are rated.
1. In DVD Stop mode, press SETUP.
2. Select Others > Parental.
3. Select the desired Parental Control
rating from "1 Kids" to "8 Adult", then
press ENTER.
4. Enter your password using the 0-9
keys, then press ENTER.
• The factory default password is
3308. If you forget your password,
this will always work.
Password
Changes the Parental Control password.
2. Select Others > Password.
3. Enter your old password using the 0-9
keys.
4. Enter your new password.
5. Re-enter your new password and
press ENTER.
Mar 05, 2011 | GoVideo DV2150 DVD Player/VCR
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
My Memorex 2040 dvd player gives "error parental" when I try to play a dvd. Any idea what this is or how to fix?
The Parental controls for your DVD player has been turned on. The default setting for most Parental Control setup is G rating meaning that anything above a G rating will not play unless the override code is entered. I was unable to locate a copy of your manual, but if you look in your copy for a heading called Parental Controls, it should explain to you what has to be done to either change the rating or remove the control altogether. Unless you have small children that may use your player you can probably remove the controls altogether. Normally you would have to go into your Setup menu, and then look for Parental Controls in that menu. Unless someone setup a code, you should be able to go in and just turn it off. If there has been a code applied and you are unable to find out what it is you will have to contact Memorex support to find out how to remove it. To ensure that it doesn't get turned back on you might want to hide your remote, as you need to use it to turn the feature on and off.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Memorex MVD2040 DVD Player
Unlock instructions for Toshiba dr570 DVD
Hello
Turn on your DVD player and television. Select the appropriate input source for your DVD player on your television.
Press the "Setup" button on your DVD player's remote control to display the main menu.
Navigate to the "Rating" menu option using the "Down" button on your remote control. Choose the "Parental Control" item by pressing the "Right" arrow button, followed by "Enter."
Enter the parental control access password using the numerical pad on your remote control, followed by the "Enter" button. If you did not previously setup a unique password, enter "8888" when prompted for the password.
Press the "Enter" button to display the parental control rating menu. Select the "8: Adult" menu selection by pressing the "Up" or "Down" directional buttons on your remote control, followed by "Enter." Press the "Open/Close" button on the front of the DVD player to complete the process.
Nov 21, 2010 | Toshiba DR570 DVD Recorder
MY CHILD OF 3 YRS OLD ACCIDENTALLY PUT PARENTAL CONTROL ON MY DVD/VHS COMBO IS THERE ANY WAY TO UNLOCK IT
By parental control I don't know if you mean child lock. If that's the case you should be able to turn it off by pressing child lock on the remote control until off shows in the display window.
Aug 07, 2010 | GoVideo DV1140 DVD Player / VCR Combo
Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
Jul 07, 2008 | Disney Princess DVD Player
Parental code
although my situation was a bit different, part of msimeomix's solution still worked. after entering the password "3308," the screen went blank. i knew this parental code had worked but it would still not allow me to access the "setup" or "menu" options. i pressed "STOP" and then ejected the disc/turned the DVD player off. upon turning it back on and entering the password "3308" i was able to immediately press "PLAY" and it worked. enjoy the movie :]
Mar 23, 2008 | Daewoo DV-6T955B DVD Player/VCR
Parental control
i posted the site on tips and tricks where you will find the manual.parental control 8 is the default setting. the factory setting password(enter this in the new password bar)is 3351 and youll have to take it from there.it seems you have a password on your machine you can change it to your own with the factory setting number.good luck, SLEWEY.
Feb 16, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd needs password
do you have the parental controls turned on in the dvd player for viewing preffrences .age, restrictions ,other .
or similar ,
riz.
Nov 12, 2007 | Akai Region Free Player
How do you reset the parental control code?
Called Zenith.  They said: turn on the DVD player.  Hit "set-up". Scroll down to the "lock" icon.  Scroll over to "Rating". Scroll over to unlock.  Enter 0000.  Click on Ok.  Enter 0000 again, click Ok again.  Menu should read unlock.  Voila!
Aug 24, 2007 | Zenith DVB412 DVD Player
KLH DVZ-2500 System Logo
100 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vincent G
Vincent G
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
