Canon Pixma MG8120 InkJet Printer Logo
Jason Kunst Posted on Mar 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where to download servicetool.exe for canon
I need to reset my canon printer where can I get the service tool
Scott P
Level 3:
  • Master 1,087 Answers
  • Posted on Mar 23, 2015
Scott P
Master
Level 3:
Answers
1087
Questions
Helped
262582
Points
2538
5helpful
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
20helpful
4answers
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : [email protected], thanks God bless U
2helpful
My printer is not functioning is sez error 5B00 what does it mean
Hey welcome to Fixya.
Error 5b00 means the waste ink counter is full, you need to reset it.
First of all to solve it you need to download PCM Service tool. Download it from Here
After downloading follow these instructions
Step 1
: Enter in service mode in order to used the re setter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button
  • Keep holding down Power button and let Resume button go
  • Then Press Resume button 5 times then let both buttons go
  • The Alternate Blinking error is gone, the printer is in Service Mode state
Step 2:
  • Extract the PCM servive tool resetter and then double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • You have done.
Credit for solution goes to
uxair shah
2answers
How do i clean the ink absorber on a canon pixma ip 1200 printer
Simply use a 1 to 5 soap to water ratio, and dip a small rag into this solution. Then gently wipe the area you would like to clean.
Waste ink near full
if the waste ink absorber is full, you need to reset it.
After clicking downloading will automatically start
Step 1
Step 2:
  • You have done.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Waste ink absorber full
Step 1
Step 2:
  • You have done.
5helpful
How to clear error 5B00 on Canon MP258
Step 1
Step 2:
  • You have done.
2helpful
Error:5B00
Step 1
Step 2:
  • You have done.
Absorber is full error 5B00
Step 1
Step 2:
  • You have done.
2helpful
My canon 1980 printer is 2 month old. and now it says "the ink absorber is full contact the service provider" how can I fix it?
it's normal.. dont worry..
You need reset yor ink tank..
follow this step to reset yor absober ink full....
firstly you need to download ip service tool
servicetool 1> Click here to download
servicetool 2> Click here to download
After download finish
1> turn off printer power switch
2> press and hold on/off button
3> turn on power switch
you will see your printer led bilnking
4> release printer on/off button
5> on printer again until led stable not blinking and you can start use ip service tool
Hope this can hope
old marine
old marine
ZJ Limited
ZJ Limited
