Question about Protron PLTV-4250 42 in. LCD Television
How do i fix protron
I have red screen how do u factory restore it
Posted by john on
Jerry LaRosa
    New Friend:
  • 17 Answers
Here is a great link for the manual:
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=21#manual
Try page 21 through 25. There is no "factory restore" function, but you can adjust the hue and colors.
Hope this helps. PROTRON PLTV 4250 User Manual Using The Remote Control
Posted on Mar 24, 2015
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
Protron pltv no tv signal
Unplug it for about an hour to see if it will reset itself first. This TV is known to have power supply problem, but yours has 5vdc standby working because the red light on the front is on, and the screen is also lited up blue. The problem can be the processor in the main board and will need more troubleshooting if that is the case.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
Jul 11, 2010 | Protron PLTV3250 32 in. LCD Television
I have a protron dvd pds 2315, hooked up to a Insignia LCD HDTV, the sceen is completely pink when I turn on the dvd player. I am using the 3 color coded video cable and a regular white/red cable for...
Turn on your DVD player, go to your set up button on the DVD remote, go to TV and select p-scan. It fixed my problem. My screen was all blue before I did that. Hope it works
May 07, 2010 | Protron PDS-2315 Theater System
No picture/sound
power supply going bad. or went bad.
get one here. The have the best price.$60
and not $100-150.
http://www.power-on.com/lcd194-3f.html
Mar 17, 2009 | Protron PLTV-4250 42 in. LCD Television
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
I have a problem can you help???
This set model has power supply problems that Protron does not seem to want to fix. The problem is leakage in a diode that eventually shorts a filter capacitor...poor design. Be prepared to buy a power supply board. This is not a component quality issue, it is a P_ss poor design.
Oct 03, 2008 | Protron PLTV3250 32 in. LCD Television
Protron 32
It looks like the power supply failed on your TV. The failure rate is about 95% in the power module.
There aren't service parts available to swap the entire assembly, the only option now will be to fix the power supply to the component level.
Let me know if you need more assistance. You can write to my email address [email protected]
May 08, 2008 | Protron PLTV-32 Television
Connect desktop PC w/ DVI and get a red screen
Fixed my own problem lol. Video card needs to be replaced.
Apr 25, 2008 | Protron PLTV-32 Television
Protron PLTV-4250 42 in. LCD Television Logo
156 people viewed this question
Top Protron Televison & Video Experts
matt martin
matt martin
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
