Question about Samsung Refrigerators
Water pooling under bottom bin in refrigerator
Tom Chichester
    Top Expert:
  • Samsung Master
  • 56,040 Answers
The defrost water may not be getting to the drain because the refrigerator isn't level or the drain is clogged.
Posted on Mar 22, 2015
Water is pooling under vegetable bin at bottom of refrigeraqtor. Seems water is coming from insude refrigerator under freezer shoot. Placer plastic cup under it and it has collected water that froze....
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 19, 2010 | Whirlpool Refrigerators
Model TBX21KLK water pooling UNDER vegetable bins
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 21, 2009 | Refrigerators
There is water collecting inside my refrigerator.
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
heatman101
Aug 11, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Mar 21, 2008 | Refrigerators
Water pooling under my express thaw bin in bottom of refrigerator
no connection between lower drawer and water dispenser, however there is a water tank behind the crisper's storing water for the dispenser, its possible that there is a hole in the tank or a connection is leaking there and dripping water. remove all 3 crisper's and give a look at it. try getting water from dispenser while your checking (Might only leak when water dispenses
Mar 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
80 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
