Wahl Adjustable Chromado Cord/Cordless Pet Clipper Logo
R
Rhoda Posted on Mar 22, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Balde keeps popping off. how do I adjust..exactly?
Anglia Clipper Services
Level 2:
  • Expert 193 Answers
  • Posted on Aug 26, 2015
Expert
Level 2:
Answers
193
Questions
0
Helped
83572
Points
240
The blade should have 3 locating 'lugs' 2 either side and 1 at the rear if any of these are broken then its a blade problem and you will have to buy a new blade.
2answers
Does wearing a hat promote baldness?
oh PA-leeze. Don't you have anything better to do with your time?
Where does a bald eagle live?????????????????????
Bald Eagle National Wildlife Federation
Their range extends from the Mexico border through the United States and Canada. Bald eagles are extremely populous in Alaska! If you live in Alaska, along the East and West coasts, the Rocky Mountains and the Mississippi River then you can see bald eagles all year. The rest of the United States only sees bald eagles during the winter and their migration.
President club car golf cart front tires wear out every 3 months.
Maybe your front end alignment is off?
Measure the distance across the front of the front wheels and across the rear of the front wheels.
On this cart the measurements should be almost exactly the same.
Measure carefully as the measurement needs to be exact.
If the measurements are not the same,adjust one or both tierods to make the distance between the front and rear of the front wheels the same.
TIP:AVOID sharp turns on pavement which will also accelerate tire wear.
Inside of front tyre going bald
Just one tire or both? Likely you need an alignment done, but other things can cause tire balding and cupping. Brakes pulling to one side or other can also cause tires to wear prematurely and unevenly. Worn Shocks/Struts are also culprits. Worn or broken bushings in the suspension. Also, bearings starting to seize up can cause this as well. In other words, a BUNCH of things can cause the problem. If you have no issues with steering, handling, braking, it is likley just a simple alignment is needed. Take it in to a reputable place and they can diagnose the exact cause and suggest repair needed. Good luck.
My clippers just stopped working...just gives a light buzz
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
I bought a new balde for hax saw and somehow i get the new balde inn, everytime i tried to tightenning it always lose.
it there is not enough adjustment left to tighten the blade the frame is bent or you have the wrong blade.
2answers
My car shakes and jerks to the right. I think i need an alignment. Could bald tires make a car shake and ****?
No, bald tyres can only make the car skid to their side not shake or **** it. It could be brake adjustment gone out too.
2answers
Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Rs2556sh side by side samsung - fridge side door will not stay shut
i have the exact same problem. Let me know if you find a solution.
Top Wahl Pets - Others Experts
Kardoc
Muhammad Tanveer
Sierra
Sierra
Level 1 Expert
Are you a Wahl Pets - Other Expert? Answer questions, earn points and help others
