hi Joyce.
is this a electric train set or a battery set?
could you please give me more info on this please.
can you please tell me what train set this is.
or go to this link might help you out on how to put a train set together. how to put train track together Google Search
Dash Zip-Line Bridge:This picture shows the layout of the track. Each section of track has a number on the bottom. Just put the sections together according to the map.
Not sure what instructions you need, but the setup is very simple.
1. Put your track together
2. Attach the track power connector by slipping it under the track and pushing, then lift up the other side. This will make the two metal contacts connect to the track.
3. Plug the connector from the power pack into the track module (It should only go one way)
4. Plug the control box (looks like a telephone cord) into the track module, Will only go one way
5. Place the locomotive on the track.
6. Place the Treetop Tender on the track (you need both to make it run)
7. Connect the large connector from the treetop tender to the loco
8. Turn on the command module and press forward ...
