Question about LG 32LD450 32 In. LCD HDTV
When I hook up DVD player to 32inch LG television there is no color on the TV it plays in black and white. Why?
Posted by neal pigorsch on
Kristine
    Sergeant:
  • LG Expert
  • 294 Answers
Generally, the main causes of the problem are included in the following aspects.
1. The incorrect TV and DVD broadcast formats. NTSC and PAL are two of the world's major TV broadcast formats, but they vary depending on how often the system projects color images.
2. Incorrect cabling. If the image connected to the DVD player turns black and white, then check if the connection to the TV is correct.
3. The backlight of the TV screen is abnormal or broken.
4. Objective factors, like whether and connection signal.
You can refer to this article "Why is My DVD Playing in Black and White" and it tells the reasons and how to solve it.
Posted on Feb 14, 2020
larry lease
    New Friend:
  • 56 Answers
First check color level setting on the tv when on av source input. double check input you are using, yellow video input (not green)
then try another device in that same input, then try the DVD player on another tv. The problem will be either DVD player or incompatibility or bad main board in TV, but usually a DVD or compatibility problem(cheap DVD player)
Posted on Mar 22, 2015
5 Related Answers
Anonymous
  • 148 Answers
SOURCE: VCR/DVD setup for color on LCD TV
check to see you have the cables required by the tv. usually you need hdmi or dvid for hd display. digital rights management protocols have resulted in chips in playing devices that allow only the use of the referenced cables to protect content from being copied. in some sets they default to not playing in hd, but still play something.
look there first, otherwise you may have an input source mismatch. follow instructions on the dvd player first, then make sure the tv has compatible settings.
if that does not solve, you have a service issue with one or both.
good luck
mark
Posted on Dec 23, 2007
Anonymous
  • 440 Answers
SOURCE: LG Plasma television
ya return it then asap ok cheak out samsung way nice t5054 model ok this ones know for issues
Posted on Feb 11, 2008
Danmart
Daniel Martinez
  • 291 Answers
SOURCE: hooking up the dvd player surround sound to be able to hear the television thru it
jimmy4151:
Name & model # of television & DVD player, Please.
Usually if the DVD player is not an Amp, then the surround sound comes from the DVD player through the TV out through the speakers??
Posted on Jun 16, 2008
Anonymous
  • 49 Answers
SOURCE: dvd hookup problem
youve hook up plugs wrong im asuming youve hook it up using componet plug featuremach colours so same plugs are in same colour holes//oz
Posted on Jul 25, 2009
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Posted on Dec 01, 2009
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Televison & Video
Hooked up cable box, wii box and dvd player to new lg 50 inch 720p plasma tv... all external components work, however, dvds and wii only show in black and white - no color...
Dec 01, 2009 | LG 50PX5D 50 in. Plasma HDTV
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
May 02, 2008 | Televison & Video
DVD plays only in black & white
Try turning on component (cable) for the V2 input  on your TV
Dec 18, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
DVD PLAYER PLAYS BLACK AND WHITE
sir/maam it is possible that the DVD player is not compatible with colored tv,s or one more thing is kindly first adjust the screen focus of your tv,,,,thnksss and hope to help you!!!more power
Nov 25, 2007 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
LG 32LD450 32 In. LCD HDTV Logo
264 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
